Just Wondering ???
I just wondered there, alot of you guys are big on engine swaps?
what other kinda honda blocks go ino eg civics? other than b16a, b18b, b18c? :p and can someone post links to examples!! |
what other kinda honda blocks go ino eg civics? other than b16a, b18b, b18c? :p and can someone post links to examples!! If I can't sell my hatch for $2500 (running), I might swap a turbo Mitsubishi 4g63 into mine. You can make any engine fit in that chassis if you're crazy enough. Check http://tech.hybridgarage.com/tech/5gtech/frog.html or try the search button. ...most of the links I have don't work anymore because I don't stay up on Honda tech like I used to. |
u cant fit D, B, H, and even K series now, I think that's pretty much it
Originally Posted by Jafro
This is waaay too broad. There are too many engines that will fit to make it practical to post. Dozens of forums exist for hybrid swap info. Just about every engine that starts with a B or a D will fit, some years fit better than others, and picking the donor should revolve around how much work and cost is associated with making the engine fit.
If I can't sell my hatch for $2500 (running), I might swap a turbo Mitsubishi 4g63 into mine. You can make any engine fit in that chassis if you're crazy enough. Check http://tech.hybridgarage.com/tech/5gtech/frog.html or try the search button. ...most of the links I have don't work anymore because I don't stay up on Honda tech like I used to. what bigger dohc vtec lumps other than what i mentioned can the ivtec engine go in |
i should have narrowed it down..
Originally Posted by 18secFerio
blasphemy :db:
Haltech! :D
If you 4G63 a Civic, I will be there to watch. I've been thinking about that swap for a while, but I'd never do it myself. |
what bigger dohc vtec lumps other than what i mentioned can the ivtec engine go in K20/22 from EP3/RSX |
Originally Posted by Max Windu
H22A from a Prelude. K20/22 from EP3/RSX that answered my question!! but all other replys were interesting too!! What model comes with Mitsubishi 4g63? And while on subject do you get the 1.6 dohc mivec engine by mitsubishi?? It is same spec as b16a (160-170bhp) |
