Climate Control Question
Old Nov 16, 2004 | 07:18 AM
Jimax's Avatar
Jimax
Default Climate Control Question
The slider levers for the temperature and fan speed are not lit up at night. Like there is no indication as to where they are set. I notice that the little handle has what appears to be a clear plastic insert that looks like it would allow light to come through. I'm wondering if mine are burnt out or are they all dark. Everything else on the climate control lights up, the buttons, the icons, the blue/red lines for cold/hot, the fan numbers, everything. I just can't tell where those two bottom levers are.
Also, the little handle on my temperature adjuster is falling off. It seems the actual black lever behind the handle is broken. Is this fixable?
Old Nov 16, 2004 | 07:47 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
if you take out that whole center section then you will be able to take out the climate controll part. there are 2 light bulbs there that probably just need to be replaced. with the handle you could just glue it back into place.
Old Nov 16, 2004 | 07:58 PM
Jimax's Avatar
Jimax
ah light bulbs...I'll check those out. Thanks!
Old Nov 17, 2004 | 09:10 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
from what I've seen in there, there are 2 light bulbs that light up the display part of the climate control, but nothing that lights up the lever itself.
Old Nov 17, 2004 | 12:52 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
get some amber bulbs and be JAYDEEEM, yO! :chuckles:
Old Nov 17, 2004 | 06:48 PM
Jimax's Avatar
Jimax
haha
uh, no!
