d16y8 tranny on d15b7
will it bolt on? will i need to modify anything? KThnxBye
if i understand this correctly...all d series will bolt together no problem
someone plz correct me if i'm wrong |
I believe itll bolt on fine. |
it will bolt on without any problems.
100% perfect fit. What you doing? Are you gonna swap tranny on your ride? Holla if you are I will help.
this is a "no holla" zone :chuckles:
the trannys will bolt up... the only problems I could see is if you're going auto->manual |
sweet thanks, im just changing my DX tranny for the EX one that i had ad im getting it rebuilt, maybe with some closer ratio gears :rick:
Edit: mikemerc85 = joepannone on some occasions :oh: |
since the tranny came from an OBD2 motor, will that make it more difficult to hook up everything. or can i just put the tranny on go?
