exhaust flange doesn't line up
Old Sep 20, 2004 | 08:10 AM
vxn12's Avatar
vxn12
Default exhaust flange doesn't line up
Hi,
Just swapped a B18B into a '94 del sol. The exhaust flange doesn't line up exactly to my stock exhaust system (exhaust pipe right before the CAT Conv). What do you recommend I should do? Thanks!
Old Sep 20, 2004 | 10:21 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
how far off is it? its supposed to line up. try checking if its hitting anything.
Old Sep 20, 2004 | 10:32 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
lemme guess. the motors exhaust bolt pattern is like \ while the stock exhausts bolt pattern is like /. i had that problem. i just clamped the two pipes together with a clamp and then drove to the exhaust shop.
or if you could always hack job it like... so.
Old Sep 21, 2004 | 04:56 AM
vxn12's Avatar
vxn12
Yep,
the bolt pattern is like that. how much did you pay to cut off one flange and align it? Which flange did you cut? thanks
Old Sep 21, 2004 | 07:46 AM
jeterkm02's Avatar
jeterkm02
i ended up gettin an entirely new exhaust. but yeah it shouldnt be more tehn 10 bucks or so. all you have to do is cut one flange off, rebolt it on and then weld it back on to the pipe. easy as cake.
