Need some help with a 97 civic cx
Old Sep 19, 2004 | 11:32 AM
xxxsmacker's Avatar
xxxsmacker
Default Need some help with a 97 civic cx
I have a 1997 civic cx hatchback. It has a D16 y7 engine in it. The car used to Idle at about 1000 rpm. Just the other day I removed all the air conditiong crap under the hood and now it idles at 500 or lower and sounds like it's going to stall. What's going on or what the hell did I do wrong.
Old Sep 19, 2004 | 03:32 PM
varyda's Avatar
varyda
You sure you didnt remove the fans to cool off the engine and now it overheats?
Old Sep 19, 2004 | 04:19 PM
xxxsmacker's Avatar
xxxsmacker
The only fan I removed was the one bolted to the condenser. The radiator fan is still in and works just fine.
Old Sep 19, 2004 | 05:48 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
500 isnt actually a bad place to idle at..
Did you remove something you didnt realize you did?
Old Sep 19, 2004 | 06:34 PM
bambbrose's Avatar
bambbrose
did you disconnect the battery when you removed the AC?
Old Sep 20, 2004 | 01:24 AM
xxxsmacker's Avatar
xxxsmacker
Yes I disconnected the battery to remove two lines that were located behind it.
