aiming headlights
Old Sep 11, 2004 | 10:21 AM
bm3r's Avatar
bm3r
Default aiming headlights
how do you aim the headlights on an eg civic? i lowered my car a good 2.25inches, and my beams are pointing kind of low. plus ive gotten a lot of comments on how one side is higher than the other. i also have the silverstars, and am really happy with the output, it just sucks cause the solid beam only extends about 5-6 feet in front of me.
thanks!
oh yeah, does anyone have pics of these..
on their car? or the real jdm's? im looking for a set of kind of smoked headlights...
Old Sep 11, 2004 | 11:07 AM
Nelson's Avatar
Nelson
Administrator
thanks!
Those headlights look pretty
About the headlights:
-Set your correct tire pressure, and then park the car on a flat surface facing a wall, parking 25 feet away.
-Measure from the ground to the center of each headlamp and mark this spot on the wall.
-Measure the distance between the headlamps and mark this on the wall.
-Turn the lamps on.
-Center the high beam on the mark on the wall.
-Stand behind the car and make sure the beam is parallel to the direction of travel of the car.
-Check your adjustment by switching to low beam.
-The low beam horizontal cut-off should fall about three inches at 25 ft. below your mark on the wall for the center of the headlamps.
-Finally, take a test drive, as aiming is partially a matter of personal taste and vision.
For driving lamps, aim them as you would your high-beam headlamps.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Sep 11, 2004 | 11:08 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
there should be some screws on the headlights that allow you to aim the lights, one screw for up and down and another for side to side
