Need Code Help ASAP
Old Jul 2, 2004 | 05:03 PM
civic sleeper's Avatar
civic sleeper
Default Need Code Help ASAP
Help!! Just did a 95 B18B swap into a 92 Honda Civic. I'm pushing these codes:
5
15
21
22
I know what they are, I just need to know how to fix them. Thanks.
Old Jul 2, 2004 | 06:37 PM
Kai's Avatar
Kai
Rotorphile.
Map sensor (probably broken or unplugged)
Ignition output signal (distributor?)
VTEC Solenoid Valve (wrong ECU)
VTEC Oil Pressure Switch (wrong ECU)
Sounds like you're using the wrong ECU. He needs a 92-93 PR4 or 94-95 P74/75.
Old Jul 2, 2004 | 06:55 PM
civic sleeper
it says mechanical though but can i use my d15 map sensor
just replaced it
its a p75 but it was used on a b20 before
i got 2 ecu's i'll try the other one
Old Jul 2, 2004 | 07:57 PM
Kai's Avatar
Kai
Rotorphile.
A non-VTEC ECU won't throw VTEC codes, so something is up with that thing. Let us kow what happens with the other ECU's.
Old Jul 3, 2004 | 11:38 AM
civic sleeper
well i checked the map sensor n everything was fine so i check the voltage n nothing so i follow the wires back to the body harness and all three plugs on the body harness side are empty n the wires that are suppose to lead there are in different spots wtf! the only thing i can think of its cause im using a auto eng harness with a manual body harness? any help would be awesome n would this make my car run rich
Old Jul 4, 2004 | 06:47 PM
civic sleeper
can i use my civic harness on the teggy motor
Old Jul 4, 2004 | 07:12 PM
Kai's Avatar
Kai
Rotorphile.
Yes.
Old Jul 4, 2004 | 08:05 PM
civic sleeper
will everything plug in or will i need to run some stuff? n the reason i was running the vtec code is cause im wired for vtec and one of the plugs on the teggy harness is connected to it! the teg harness is really f'd up
