Can I Do It Myself??
Old Jun 17, 2004 | 06:02 PM
3rdgenlxi's Avatar
3rdgenlxi
Default Can I Do It Myself??
I've gotta replace the clutch slave cylinder / clutch master cylinder. is this a one man job.... cause i don't think my wife is gonna be much help!
95 civic ex sedan
SOHC ZC Vtec swap - but clutch cylinder is stock usdm
Old Jun 17, 2004 | 07:26 PM
Outxider's Avatar
Outxider
X-Motoring
replacing it is a one man job, bleedin will require one more person to make things easier.
Old Jun 17, 2004 | 08:28 PM
honura's Avatar
honura
Seni
Bleeding is simple. Just tell your wife to pump on the clutch and hold thats all you gotta do pump 3-5 times and hold the pedal down. Bleed the line and tell her to do the samething till there is no air in the lines thats it.
Old Jun 18, 2004 | 06:52 AM
3rdgenlxi's Avatar
3rdgenlxi
Sounds simple enough... I'll prob do it on sunday. If successful i'll post pics, if not oh well.
Old Jun 18, 2004 | 07:57 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
the clutch wont build pressure like the brake system will so pumping it will just make your leg tired. You can just tell her to hold it down, bleed it, close it, release the clutch, repeat. Oh dont forget to refill your fluid about every 2 times.
Old Jun 18, 2004 | 11:50 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Easy. Hour and a half tops... and thats if youre drinking heavily (took me about 30 min I think). I did mine all by my lonesome... I just routed a hose out of the bleed valve to somewhere where I could see it from the drivers seat.
