Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   92+ Civic/EL & Del Sol (https://www.honda-acura.net/forums/92-civic-el-and-del-sol-6/)
-   -   I can't get the pin out (https://www.honda-acura.net/forums/92-civic-el-and-del-sol/139462-i-cant-get-the-pin-out.html)
civicburner May 13, 2004 04:55 AM
I tried to change the gas and brake pedals on my car because I did an auto to manual swap. I was able to get all the nuts off, disconect the throttle cable, but when I tried to get the pin out of the brake pedal that connects it to the brake booster(I think that's what it's called), it wouldn't budge. I yanked at it with a pair of pliers, but no luck. Does anyone know how to get it out?
93DelSolSi May 13, 2004 05:01 AM
Pics ?
+ i was thinging of doing a auto to 5 spd. How much did it end up costing you to do it ?
westcoaststyle May 13, 2004 05:17 AM
There's a cotter pin that holds the keeper pin on the MC push rod to the brake pedal.
Before yanking and pulling on it with a pair of pliars, step away and come back later. You will break something if you force it...
civicburner May 13, 2004 06:06 AM
yeah did that...came back the next day, but still no luck
civicburner May 13, 2004 06:07 AM
Originally Posted by 93DelSolSi
Pics ?
around $450 all together
westcoaststyle May 13, 2004 06:12 AM
Did you remove the cotter pin and the keeper pin?
civicburner May 13, 2004 07:37 AM
which is which? I'm trying to remove the flexible pin that is inside that other pin. The pin that is bent around the other one. I bent it up straight and tried to pull it out, but it won't come out.
wilsel May 13, 2004 08:05 AM
If I remember right it has a release on the other side of the cotter pin. You have to unhook it (kind of like a safety pin) before it'll come off. A picture would really help better than words.
Kind of like this:
http://www.zycon.com/images/CompanyG...51/grip(t).gif
westcoaststyle May 13, 2004 08:09 AM
You have to remove that pin or the keeper won't come out. Cut the back half of it off with some wire cutters and then pull it out. It can be a pain because if it's bent at all it probably won't want to come out. That is your problem though.
civicburner May 24, 2004 12:57 PM
I got the damn pin out and took out all the screws, but I still can't get the pedals off. There isn't enough room under there to maneuver. I even dropped the steering column but that was no help at all. If that metal piece the brake was connected to on the firewall wasn't there it would be extremely easy. How do I get the pedals off from here?
© 2026 MH Sub I, LLC dba Internet Brands
