Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   92+ Civic/EL & Del Sol (https://www.honda-acura.net/forums/92-civic-el-and-del-sol-6/)
-   -   whats a b16a's top speed? (https://www.honda-acura.net/forums/92-civic-el-and-del-sol/138804-whats-a-b16as-top-speed.html)
pez May 8, 2004 09:28 AM
i swapped a b16a into my 93 civic dx that doesnt come with a tach, i bought one..but then that was stolen, so now i just want to get a cluster that has a redline at the right spot (8200) and has a top speed higher or equal to what my car can push, what cluster would i be looking for?
Smurf May 8, 2004 09:48 AM
a tachometer with 8200 rpm.
white_n_slow May 8, 2004 09:54 AM
a jdm cluster will have the right redline and fit properly if you don't mind reading kph.
otherwise, a gs-r cluster can be swapped without *too* much trouble. Do a search, I think Outxider and maybe some other members have done this. The actual redline will be a touch lower, but there will be more than enough room on the tach to rev out the b16a as far as it will go. I think the speedo goes to 140 or 160 or something :thinking: either way, its far faster than your civic will ever go. :)
Smurf May 8, 2004 10:00 AM
He dosnt need a speedometer faster then 120.
Kai May 8, 2004 10:39 AM
If you are using a JDM ECU, you only need the speedo to go up to 112mph. Japanese cars are limited to 180kph, which is 112mph.
qtiger May 8, 2004 02:07 PM
Drop it from a plane, I'm guessing at least 500 mph.
Bumnah May 8, 2004 02:19 PM
Um...... no.
purchase a jdm eg6 cluster. best looking. reads in kph, but you'll figure it out easily after a few days.
if not get a 92-95 civic si/ex cluster. that is all. plug and play nothing to do, other than swap them in. no special anything.
ManInCamo May 8, 2004 02:44 PM
I think with the wind resistance, it'll reach a terminal velocity slower than 500... hmm
Kai May 8, 2004 06:22 PM
Originally Posted by Bumnah
Um...... no.
When did they stop using the 112 limit then? That's the way most JDM-land cars I know of are set up.
khmy2ner May 9, 2004 12:14 PM
It's 127mph
© 2026 MH Sub I, LLC dba Internet Brands
