want to see if this is ok
Old Apr 17, 2004 | 07:05 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Default want to see if this is ok
i want to put 97 ex rotors on my 94 dx. they are bigger rotors, so would i just have to get the caliper bracket from the EX and put it on the DX to relocate the caliper to make room for the larger rotor? and would this be a straight-forward swap without any difficulty? any help would be greatly appreciated. thanks
Old Apr 17, 2004 | 08:41 AM
Nelson's Avatar
Nelson
Administrator
I would assume if the rotor thickness is the same, then all you would need is the caliper brackets.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Apr 17, 2004 | 12:26 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
sh!t i just tried it....no luck, i need the whole spindel from the ex to make it work. the bracket for the caliper didnt fit flush with the bolt holes so i just grinded the bracket a bit to make it sit flush. then with the rotor on, the bracket wouldnt slide over because of the thickness of the disk. the things i need are the bracket, caliper, rotor and spindel from the EX, but the question is, would the spindel from a 97 ex bolt onto the 94 dx???
Old Apr 17, 2004 | 12:59 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
to bad I didn't get to this earlier, i was gonna say you need the whole setup. luckily, its pretty cheap.
I dunno if i would trust impromptu custom ground brake work :eh:
get integra rear disks too I have them, i love my brakes.
Old Apr 17, 2004 | 02:08 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
well i have a whole 97 ex that im using for parts so i just need to get a weekend and do the whole job(swap over all components from the 97 to the 94).
Old Apr 17, 2004 | 02:21 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
just want to know what else i would need to do the swap
Old Apr 17, 2004 | 11:50 PM
dantastic's Avatar
dantastic
cx power!
you need 92-95 4dr EX knuckles. well those are the ones that i know will work for sure.
Old Apr 18, 2004 | 02:15 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
would the whole 97 EX system bolt on to the 94???
Old Apr 18, 2004 | 04:55 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
You need the knuckles with the rotors and calipers (just leave it bolted together), and you may need the brake lines too. The '97 stuff should fit fine
Old Apr 19, 2004 | 05:48 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
sweeeet! now all i haveta do is put them on! thanks white n slow
