what is is a safe amount of nitrous to run
Old Mar 25, 2004 | 10:27 AM
forcfedcivic's Avatar
forcfedcivic
Yes, i drive a civic
Default what is is a safe amount of nitrous to run
i was wondering what is a safe amount of nitrous to use on a stock D15B7. and keep in mind it will only be used at my local dragstrip.
Old Mar 25, 2004 | 10:29 AM
Running925's Avatar
Running925
Your Powder Coater
Wet or Dry?
What type of fuel delivery?
Old Mar 25, 2004 | 10:32 AM
forcfedcivic
sorry it is dry.
Old Mar 25, 2004 | 10:45 AM
Running925's Avatar
Running925
Your Powder Coater
I'm guessing your using a stock fuel system?
Old Mar 25, 2004 | 12:22 PM
forcfedcivic
yes stock D15B7 but will upgrade to better fuel rail and pressure reg. and injecters before runing the kit.
Old Mar 25, 2004 | 12:37 PM
Section8Blammo's Avatar
Section8Blammo
Crazy Canoodler
55 jets should be fine.
Old Mar 25, 2004 | 12:40 PM
Running925's Avatar
Running925
Your Powder Coater
As long as u'r not going to starve the engine from fuel durring using the Dry kit you can run a 75shot on it without hurting anything.. Just make sure that you have it tuned so that there is enough fuel pressure!
Old Mar 25, 2004 | 12:45 PM
forcfedcivic
and what kind of HP gains am i looking to gain with a 55-75 shot?
Old Mar 25, 2004 | 02:15 PM
cobbcustomz's Avatar
cobbcustomz
those numbers are the HP roughly at least it is on the ZEX kit
55 shot dry = 50 WHP
Old Mar 25, 2004 | 02:19 PM
Im@ge's Avatar
Im@ge
So ugly it hurts..See?
um..might aswell get Zex if you arent that experienced wth Nitrous systems..reason being,it come swith its own computer for fuel and Nitrous regulation..so you can basicly run it all day with the propper fuel Nitrous ratio! good stuff..good luck..
