Swap
Old Mar 19, 2004 | 03:21 PM
Nikon44's Avatar
Nikon44
Default Swap
I have a friend with a 95 EX coupe. He just got a B16a1 from a 89-91 CRX. How hard is this swap? If I am not mistaken he has an OBD1 engine if not please correct me.
Old Mar 19, 2004 | 03:37 PM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
your friends engine is OBD1
the b16 is OBD0
correct me if im wrong, but im prety sure
Old Mar 19, 2004 | 04:33 PM
Civic2Scooby's Avatar
Civic2Scooby
the b16a is obd0
you will need to convert to obd1 and get an obd1 p30 ecu
the convert includes but is not limited to....obd1 b16a,b16b,b18c distributor, obd1 injectors(the ones off the ex will work fine) I would also HIGHLY recomend switching to a p30 intake mani with p30 or better throttle body so you dont have to T fit the vacuum lines to accept the firewall mounted map sensor...also he will have to switch over his VSS from his ex into the b16a as the b16a obd0 has mechanical speed sender as opposed to the obd1 electronic VSS....uhhh....I did this same swap to a 95 dx so any questions hit me up on PM
Old Mar 19, 2004 | 05:31 PM
Nikos's Avatar
Nikos
Is that a cable tranny on the obd0 b16?
Old Mar 19, 2004 | 05:46 PM
Civic2Scooby
yup...you will need either a B series Hydro tranny...oorrr the cable to hydro conversion kit from HASport.
95DXPhiladeph
92+ Civic/EL & Del Sol
4
Sep 8, 2003 11:41 PM
Future Swap
Engine Swaps, Tech & Tuning
Apr 17, 2003 01:54 PM
eclipse spanker
9
Dec 21, 2002 01:55 PM
VN-TEC
8
Aug 29, 2002 04:34 PM
Jkan2001
24
Aug 2, 2002 04:24 AM
