Re-wiring my b18c1 civic
Old Feb 5, 2004 | 06:00 AM
stehigs321's Avatar
stehigs321
Default Re-wiring my b18c1 civic
Hey i have a 96 civic with a 98 b18c1. To do the swap we used my stock wining harness and, extended some wiring, changed plugs on some. But would it just be easier if i get a hold of a wiring harness from that motor? WIll everything just plug in like normal then? WIll that harness work with the civic?
Old Feb 5, 2004 | 07:07 AM
qtiger's Avatar
qtiger
Yes. It'll all work.
Old Feb 5, 2004 | 02:32 PM
stehigs321's Avatar
stehigs321
But, what i want to know is, will it make the engine run perfect, or atleast be wired perfectly as if it was in a gsr integra? Does the engine wiring harness what plugs into the ECU?? How much and where can i get a comnplete 98 gsr wiring harness??
Old Feb 5, 2004 | 04:05 PM
Civic2Scooby's Avatar
Civic2Scooby
your civic harness will do just fine...it is the same harness and everything will run perfect as long as you plug in the right plug to the right sensor...I promise everything is gonna be ok... :cheers:
Old Feb 5, 2004 | 04:18 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
You have a '96 Civic, a GS-R harness will not work at all! '92-'95 Civic's (EG's) and '94-'01 Integra's (DC's) use a 2 piece harness. One is attached to the engine and has a series of plugs that connect to a second harness actually physically in the car (and remains there if the motor is removed). '96-'00 Civic's (EK's) are wired very differently. The plugs attaching to the engine are very similar, a few sensors are in different places and a few less wires for VTEC and the knock sensor (depending on how each car/engine is equiped) but the other side is completely different. EK Civic's do not have disconnects in the engine bay and an in-car harness, the entire harness just goes to the passanger side firewall, passes through it and goes right to the ECU. When the engine is removed, that whole thing comes out. You must use a '96+ Civic harness ('96-'98 harness are a little different than '99-'00 harness as well, sometimes called OBD IIa and OBD IIb) for your swap. The process of swaping the harnesses over isn't extremely complicated with both engines out of the car and a careful eye though.
Old Feb 5, 2004 | 04:20 PM
Civic2Scooby
I always forget about the stupid one peice harness in the EK's...I much prefer my EG harness...I dunno why the change
Old Feb 5, 2004 | 05:12 PM
honura's Avatar
honura
Seni
Yeah I would keep the stock one and just make sure all your connections are on good . No reason to spend cash if its not needed you know ! ?
egjoe
Nov 11, 2004 04:16 PM
SuperDave
92+ Civic/EL & Del Sol
7
Aug 8, 2003 02:05 PM
jaje
News & Rumors Archives
19
Mar 26, 2003 03:58 PM
hyperlite
Engine Swaps, Tech & Tuning
7
Jan 29, 2003 08:19 PM
jaje
17
Jun 27, 2002 03:16 AM
