Clunky tranny? How to fix?
Old Jan 22, 2004 | 05:02 PM
longskate87's Avatar
longskate87
Default Clunky tranny? How to fix?
Hey all, My '96 has an Auto tranny (I commute) and it seems not to shift too smooth. You can definetely tell when it shifts, and if you coast then push the gas again, sometimes it will lag for a sec., then quickly engage almost as if you were dropping the clutch, but it's an auto. Could the tranny need adusting or something? Thanks.
Old Jan 22, 2004 | 07:24 PM
SRT_Andy's Avatar
SRT_Andy
When's the last time you swapped the tranny fluid and filter (if applicable)? If you can't remember, you might want to do it. Honda recommends a swap every 35 or 40 thousand miles.
Old Jan 22, 2004 | 07:27 PM
Hondaman's Avatar
Hondaman
Black Pearl
Try pulling the fuse for the ECM for about 30 seconds or disconnecting the battery for about 30 sec to reset the computer. My auto tranny gets funky sometimes too and I pull the fuse and all is good for a while again. 1996 was the first year of that tranny so it has some software issues.
Old Jan 22, 2004 | 07:58 PM
aenima_20's Avatar
aenima_20
make sure you have enough fluid in it
low fluid could cause that
could that GM syncromesh stuff work in an auto tranny ??
Old Jan 22, 2004 | 09:14 PM
longskate87
Ya, the fluid is nice and clear. Will pulling the fuse on stuff do anything harmful to anything else? I may try that though. Thanks for the help, if think of anything else that would be great.
Old Jan 22, 2004 | 09:18 PM
Hondaman's Avatar
Hondaman
Black Pearl
The one thing that sucks about pulling your fuse is you lose all your radio presets cause they are on the same curcuit.
Old Jan 23, 2004 | 02:53 PM
longskate87
Ok i'll try that, I have an Alpine 9803, will it still delete the presets? I just don't want to pull a fuse and have it not start or something...
Old Jan 24, 2004 | 12:24 PM
Hondaman's Avatar
Hondaman
Black Pearl
Yeah, it will delete the presets and the time. I've got an Alipine 7894 and it does anyway. You can pull the fuse with no worries. It's just like disconnecting the battery. I've done it tons of times on mine.
