Is it worth $700
Old Jan 11, 2004 | 05:55 PM
blackandblue's Avatar
blackandblue
Default Is it worth $700
I was looking for motors and i ran across i think it is www.total-boost.com and they have a bunch of b16, b18, and so on. The b16 is $2000 and it hs 168hp and 116 torque and a b18c has 170hp and 128 torque. I planning on using a garret turbo (thanks to pauls advice) t3/t4. But i am not sure if the 2 extra hp and the 12 torque is worth 700. Now from reading the b16 has a higher top end and the b18 has more lower end. Is that true? Would you spend that $700 or performance mod?
Old Jan 11, 2004 | 05:58 PM
Paulll's Avatar
Paulll
Hail Bent
i dont know about those numbers, but get the b18c1
Old Jan 11, 2004 | 06:05 PM
MPerson's Avatar
MPerson
It's not always about the numbers it gives, but how it's designed too. The B18C is can handle boost much better than the B16, so get the B18
Old Jan 11, 2004 | 06:10 PM
s1ngle's Avatar
s1ngle
clutch slipping boost
i thought the B18 had like 200 hp??
Old Jan 11, 2004 | 06:50 PM
AciDKinG95LS's Avatar
AciDKinG95LS
SOLD THE ALLUM. WING!!!!
b18b is 142hp, and b18c is 170? and b18c5 is 195-200hp
b16a is high compression, higher compression engines can't handle boost as good. If your gonna go FI then i would get a b18b, they are lower compression and take well to boost. Plus, you ahve to make sure it will go into your car. You said b16, is that a 1 or 2? the 1 would take some extra work, the 2 should go in easily. However, in my opinion, its not worth the 700 extra at all.
Old Jan 11, 2004 | 07:18 PM
Paulll's Avatar
Paulll
Hail Bent
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp
D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130ps
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K20A3 2.0L DOHC i-VTEC '02+ RSX
/'02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S
02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps
F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp
F22A1 2.2L USDM non-VTEC 92-96 Prelude S 90-93 Accord LX/EX 130hp-135hp
F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL 150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiR S Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps
C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp
C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP
C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp
J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
*JDM: Japanese domestic market (available in Japan)
*USDM: US domestic market (available in US)
*ULEV: Ultra Low Emissions Vehicle
Accord
5G Japan '94-'97 H22 2157 10.6:1 190hp@6800/152ft/lbs@5500
4G Japan '90-'93 F20A 1997 9.5:1 150hp@6100/137ft/lbs@5000
civic
6G Japan '97-'00 B16B 1595 10.8:1 184hp@8200/118ft/lbs@7500
6G Japan '96-'00 B16A 1595 10.4:1 168hp@7800/118ft/lbs@4500
6G Europe '96-'00 B16A 1595 10.4:1 168hp@7800/118ft/lbs@4500
5G Japan '92-'95 B16A 1595 10.4:1 168hp@7800/118ftlbs@7300
4G Europe '89-'92 B16A1 1595 10.2:1 158hp@7600/111ft/lbs@7000
4G Japan '88-'91 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
4G Japan '89-'92 B16A 1595 10.2:1 158hp@7600/112ft/lbs@7000
4G Japan '90-'91 B16A1 1595 10.4:1 160hp@7600/111ft/lbs@7000
3G Japan '86-'87 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
crx/delsol
5G Europe '94-'97 B16A3 1595 10.2:1 158hp@7600/112ft/lbs@7000
5G Japan '92-'96 B16A 1595 10.4:1 168hp@7800
4G Japan '89-'92 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
3G Japan '85-'87 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
Integra
3G Japan '95-'97 B18C 1797 10.6:1 178hp@7600/129ft/lbs@6200
3G Japan '95-'00 B18C 1797 11.0:1 197hp@8000/130ft/lbs@7500
2G Japan '90-'93 ZC 1590 9.0:1 119hp@6300/105ft/lbs@5500
2G Japan '90-'91 B16A 1595 10.4:1 158hp@7600/112ft/lbs@7000
1G Japan '86-'89 ZC 1590 9.6:1 129hp@6800/106ft/lbs@5700
prelude
5G Japan '97+ H22A 2157 10.6:1 200hp@6800/161ft/lbs@5500
4G Japan '92-'96 F22 2156 160hp@5800/156ft/lbs@5000
4G Japan '92-'96 H22 2157 10.6:1 200hp@6800/161ft/lbs@5500
Rand0mb18c's Avatar
Rand0mb18c
i would definently get the b18c for 700 more its definently worth it
