crap. no D brackets.
Old Jan 9, 2004 | 12:51 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Default crap. no D brackets.
I just got my ITR rear swaybar in the mail, and it doesn't have the D brackets, just the bushings. Anybody have any idea how much these things cost? I'd prefer not to have to go to the dealer. :a:
Thanks.
Old Jan 9, 2004 | 12:57 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
www.acuraautomotiveparts.org
Old Jan 9, 2004 | 01:09 PM
white_n_slow
it's my D in a B
I didn't see it on there.
They call the ITR tie bar a "performance rod" :chuckles:
Old Jan 9, 2004 | 02:16 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
don't bother with oem, get the prothane counter part
poly bushings with d brackets
for 12 dollars
To order this kit, follow these simple instructions:
- Call JC Whitney at (312) 431-6102
- Order part number 88LT7544N (7/8" bushings & 'Type A' D-brackets)
- When you order, you'll need a catalog code.
- Tell the operator catalog number 624C & blue source code is ACYF2
- Kit is $9.95 for the set you see above.
- Takes about 7 days to get in the mail, ground shipment.
off of hybrid, the part number is listed that you need
Project EVA - The Track Package
Project EVA
Old Jan 9, 2004 | 02:18 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
I couldn't get the picture to show up, so I can't help ya... Might ahve to check with the dealer. I wanna say they're about 8 bucks a piece.
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I see you got shift working again. :chuckles:
I need to figure out those beaks mounts you sent me. :thinking:
Old Jan 9, 2004 | 02:25 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
shift key is dead still.. ctrl copy saved the day.
beaks kit is easy...
plates with sharp cuts go inside the sub frame, plates that are round around the edges go on outside of the subframe.
drill out the abs mounting point hole big enough for the bolt to go through. bottom hole on the plates go through the enlarged hole. d brackets mount on outer plate with the bolts that i left in the beaks plates. when you screw down d bracket you also screw together the two plates which in turn sandwiches the subframe between the two plates. pretty darn simple.
Project EVA
Old Jan 9, 2004 | 02:44 PM
white_n_slow
it's my D in a B
for 12 dollars
:doh: duh, thats a no-brainer. Sorry, my head must be up my ass today. I think I'll call summit and see if I can't get it any faster. Thanks.
Old Jan 9, 2004 | 04:02 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
i wanna put my itr rear sway on.
Old Jan 9, 2004 | 06:08 PM
white_n_slow
it's my D in a B
how long has that thing been in your closet, anyway?
