1995 Honda Civic LX Basic Questions Round 2:
Old Jan 4, 2004 | 09:19 AM
bob6831's Avatar
bob6831
Default 1995 Honda Civic LX Basic Questions Round 2:
Hi.
1 - How do I remove the rear brake drum - do I need a special tool, or can I just use a couple of bolts to screw into the 2 holes to push the drum out?
2 - How do I get to the emergency brake sensor? Mine appears to be not working - no indicator light on dashboard when on.
3 - Car has been sitting for a while - is rust on the front rotors. Will this cause brakes to fail inspection?
Thx.
Old Jan 4, 2004 | 09:31 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
1) you're right, just use 2 bolts
2) check the bulb in the cluster first. Easier to test than the sensor.
3) rotors will get rust on them 10 minutes after it rains. Just drive it around and the rust will work off. If it's been like 4 months, you may consider getting the rotors turned...
Old Jan 4, 2004 | 12:33 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
for the drums i have to add to get them off after you take off the 2 bolts just tap it on the top half then bottom half with a hammer. it will free the drum and be easier to remove. DO NOT try to pry it out.
Old Jan 4, 2004 | 02:52 PM
westcoaststyle
and make sure the e-brake is not engaged.
Old Jan 4, 2004 | 04:42 PM
Civic2Scooby's Avatar
Civic2Scooby
:werd: I was bangin on those beeshes for about an hour before I realized I was an idiot and had left on the e-brake....lol
Old Jan 5, 2004 | 02:39 PM
bob6831's Avatar
bob6831
Thx for the help. What is the problem with prying the brake drum to help get it off? Won't using the bolts in the 2 holes cause the drum to push far enough out to make removal simple?
Old Jan 5, 2004 | 03:09 PM
westcoaststyle
yup... done that more than once :doh:
