vtec head swap
Old Jan 1, 2004 | 12:39 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Default vtec head swap
I have a 94 civic DX with a few mods and I want vtec. I also have a totalled 97 EX. Would I be able to do a head swap from that engine to mine? Which parts would i need from that car to swap to mine? I would really appreciate some replies on this field...Thank you.
Old Jan 1, 2004 | 01:36 PM
supermac88's Avatar
supermac88
not OG but Old School
take the head off of your ex and, take the head off your dx, get you ecu from your ex run vtec wires. Actually you will need a P28 ecu out of a 92-95 ex, or Si I think.
somebody correct me if I'm wrong, just trying to help a guy out.
Old Jan 1, 2004 | 01:44 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
cant i just take the ecu and all the wires from the totalled car and put it in mine?
Old Jan 1, 2004 | 01:45 PM
supermac88's Avatar
supermac88
not sure about the wiring. The ex is obd2 and the dx is obd1 so it is different might need a p28 out of the 5th gen
Old Jan 1, 2004 | 01:52 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
so the head form the 97 is ok to make obd1? and can i just take the p28 ecu and just plug in the normal plugs? who i need to swap anything from the original head onto the vtec head to make this work?
Old Jan 1, 2004 | 02:10 PM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
Why dont you just take the whole motor from the EX and put it in the DX? It would be more work but more straight foward and the parts would all have the same mileage.
Old Jan 1, 2004 | 02:29 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
yea i can definatly do that but the thing is the car was totalled in the front and the block is buried in metal so i dont think the internals are ok...im going to pull the whole engine out and check it out. im just condsidering the head swap if the block is messed up.
Old Jan 1, 2004 | 09:05 PM
Krayzie2k3's Avatar
Krayzie2k3
check the head and use a NEW head gasket. saves time from takin the head off later on.
