have a idle problem
Old Dec 10, 2003 | 07:51 PM
sick_sol's Avatar
sick_sol
Default have a idle problem
i have a idle problem its jumping between 800 rpm to 1300 rpm
the code came up 6 flashes (temp control sensor) changed the one on the block now it still dose the same thing but when i test for codes all i get is the check engine light staying on no flashes
now i found other sensor on the thermostat hosing is that the one that controls the computer and the i should have change.
thanks
sick_sol
Old Dec 11, 2003 | 06:18 AM
sxecrow's Avatar
sxecrow
Banned
are you saying that when you're idling, the RPM's jump up and slow back down? Check the idle air control.
Old Dec 11, 2003 | 04:57 PM
G-JDM's Avatar
G-JDM
if the idling is NOT erratic, i.e. in time andat the same pace, then its the fast idle thermo valve, a small coolant valve under the throttlebody. they are made of wax and break easily.
Old Dec 11, 2003 | 07:50 PM
sick_sol's Avatar
sick_sol
were is the thermo valve located and do u have a pic of one i think i already repalced that one i have replace the map sensor, the iac sensor many of time now there is one on the back of the thermostat hosing what is that for?
thanks
