Clutch release fork issues
Old Nov 30, 2003 | 09:40 PM
draggin's Avatar
draggin
Default Clutch release fork issues
ok, i have a 00 civic si. the clutch squeaks when pressing and releasing the clutch pedal. i have already lubricated the slave cylinder where it engages the release fork, but it did not solve the problem. i am thinking it must be that the release fork itself may need lubrication or the release fork bolt. is this correct? is there anyway to lubricating these parts w/o taking the tranny apart? any help would be appreciated.
thanks.
Old Nov 30, 2003 | 09:43 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Sounds like your throw out bearing
Old Nov 30, 2003 | 09:58 PM
draggin's Avatar
draggin
how many hours am i looking at?
Old Nov 30, 2003 | 10:12 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
You might as well put a new clutch in it while you are doing it..... so I say 3-4 hours tops.
Old Nov 30, 2003 | 10:14 PM
draggin's Avatar
draggin
doesnt sound like a nightmare. thank for the help!
Old Nov 30, 2003 | 10:16 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Anytime, its not that bad but time consuming since you have to pull the tranny
Old Nov 30, 2003 | 11:28 PM
Black2000Si's Avatar
Black2000Si
I have the same problem in my Si
Old Dec 1, 2003 | 08:08 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
You should be able to pull your tranny pretty easily. The ball that the clutch fork pivots on may just need to be greased. But I would get an aftermarket clutch while you're in there. And replace the throw out bearing. If you don't race your car or don't have many mods then the oe clutch is probably fine.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
