Port matching
Old Sep 15, 2013 | 06:37 PM
334cobra's Avatar
334cobra
Default Port matching
Ok gentlemen, huge question...
How bad is a larger throttle body (in comparison to the intake mani) WITHOUT PORT MATCHING? I know it'll affect the flow of air, BUT will it affect the throttle body functioning correctly altogether? for example, idling properly/map sensor making correct readings/anything dealing with the holes and inner grooves on a throttle body. Will those holes possibly be blocked off with a smaller intake mani?
-68 mm blox tb
-skunk2 intake mani
-d16y8 engine
PLEASE HELP
Old Sep 15, 2013 | 06:38 PM
334cobra's Avatar
334cobra
Intake mani has 62 mm opening.
Old Sep 16, 2013 | 05:26 PM
334cobra's Avatar
334cobra
anyone?
Old Sep 19, 2013 | 11:38 PM
334cobra's Avatar
334cobra
[/VIDEO]
Old Sep 20, 2013 | 09:43 AM
334cobra's Avatar
334cobra
if I say pretty please will that work?
Old Sep 21, 2013 | 06:52 AM
334cobra's Avatar
334cobra
the video is of a misfire at low rpms that I am having. only low rpms though. it hesitates.
Old Sep 21, 2013 | 01:27 PM
ChrisS's Avatar
ChrisS
The ECU makes assumptions based on the car's original equipment.
Changing from a 62mm to a 68mm throttle body increases the amount of air that can be supplied to the intake manifold by 20.3% (3019.1mm^2 to 3631.7mm^2) which might be changing the fuel-to-air ratio.
(or it could be a vacuum leak.)
This is the reason tuners have programmable ROMs in their car's ECUs and do dyno work to map the fuel-to-air ratios correctly for their modified engines.
A couple of other things to do _before_ you heavily modify your car's engine/horse power(HP):
-upgrade the car's suspension to handle the additional HP
-take a real road track training class (more HP means you can/will get in trouble _much faster_ than you did with an OEM car.)
Old Sep 23, 2013 | 07:02 AM
334cobra's Avatar
334cobra
ahhhh, u know that could be it. I do have a hondata s100 on this vehicle, but it hasn't been tuned in a while. also, I do have skunk2 suspension on here as well, along with the whole front end of it upgraded with polyurethane bushings. ill look into the ecu thing. thanx!
