Are EG and DC lca/uca's the same?
Old Nov 14, 2003 | 12:52 PM
zero grip's Avatar
zero grip
Default Are EG and DC front lca/uca's the same?
according to helms the front lca/uca look exactly the same. is there any differecnce between the two in addition to the damper forks. how do they differ?
**edited** - are the front's different in any way?
Old Nov 14, 2003 | 01:00 PM
wilsel's Avatar
wilsel
Only difference I know of are the rear LCA's have holes for a swaybar on the DC. They are interchangable though. Not sure about the dampening fork ?
Old Nov 14, 2003 | 01:03 PM
dantastic's Avatar
dantastic
cx power!
dc-r rear lca's use a different type of shock mount (eye and bolt instead of fork).
most eg rear lca's do not have holes for sway bars. all dc's have provisions for a rear bar
Old Nov 14, 2003 | 01:14 PM
zero grip's Avatar
zero grip
sorry, titled edited. i was wondering how the FRONT lca/uca's differ between EG and DC.
Old Nov 14, 2003 | 01:18 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
upper control arms are the same for the EG/DC
EK's have a different setup.
....to the best of my knowledge.
Old Nov 14, 2003 | 01:22 PM
zero grip's Avatar
zero grip
thanks. how about the front lca's?
Old Nov 14, 2003 | 02:07 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Front suspension is exactly the same between a DC and EG. I had a complete Integra front suspension on my hybrid. Integra LCA's, spindle/hub assembly and upper A arms, I even used the Integra rear engine subframe (needed it to mount the Integra rack). If your civic doesn't have a front sway bar (like my CX) your LCA's won't have a hardpoint/hole to attach one, but they're the same shape/size, just like the rear setup. The entire rear assembly is interchangeable too.
Old Nov 14, 2003 | 02:11 PM
zero grip's Avatar
zero grip
thank you. that's the answer i was looking for! :thumbup:
Old Nov 14, 2003 | 03:02 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
yup. The front LCAs aren't identical, but theyre interchangable. The sole difference being swaybar mounting hole.
