b16a2 swap
Old Nov 5, 2003 | 07:43 PM
hondajeff's Avatar
hondajeff
Default b16a2 swap
when dropping the b16a2 engine into a 95 civic coupe. what other wire's do i need to run besides the knock sensor wire?? what other misc parts do i need??
I was told I need the a/c mount bracket from a b16a3 delsol motor if i want to keep my a/c.
and rear torsion mount from any b-series engine.
thanks
Old Nov 5, 2003 | 07:49 PM
95DXPhiladeph's Avatar
95DXPhiladeph
Default Re: b16a2 swap
thanks
all you need AC bracket from delsol vtec 92-95
vtec wiring harness from hasport... unless you wanna wire the selenoid yourself... vtec selenoid that is...
i think you need the 94-01 integra shift linkage... dont quote me on that though
Old Nov 5, 2003 | 09:38 PM
Civic2Scooby's Avatar
Civic2Scooby
94-01 teg shift linkage or 99 si linkage. GSR or Si rear torsion mount. Don't waste your money on the hasport harness it is easy enough to do on your own with an ecu pin out.
and do a search this has been covered more times than I can count!
