Results 1 to 2 of 2
Thread: VA - FS: 92 240sx fastback. SR powered. Solid car.
  1. #1
    So OG it hurts. Bumnah's Avatar
    Join Date
    Mar 1999
    Location
    VA
    Posts
    6,592
    So, I'm putting this up for sale to see what kind of offers I will get. The car runs great, if I sell the car I may try my hand at another motor swap on another chassis. I'm not in a rush to sell it. If it doesn't sell; I don't mind holding on to it. Just seeing what I can get out of it.
    The car is located in central VA. Garage kept.
    Chassis spec:
    92 S13 Fastback
    Black in color
    Cloth interior
    Base model
    No power windows or locks.
    Manual sunroof
    No leak in the hatch area
    Everything is operational.
    147,xxx miles on chassis
    Everything behind the front seats is gutted.
    No stereo, no speakers. Wiring for everything still there.No rust.
    Just the minor dings and dents you'd find on a 15 year old car. Paint job wouldn't hurt.
    Engine spec:
    Redtop Sr20 55k miles on it
    5 speed transmission 55k miles on it too.
    180sx rear end diff (4.36 gears VLSD) don't know the miles on it. I Opened it up, looked ultra clean, no shaving. Verified the 4.36 ratio also.
    USDM triangular axle outputs (uses oem 240sx axles instead of the 5 star JDM ones)
    Modifications (as much as I can remember):
    Redtop sr20 motor swap ($2000)
    Sr20 5spd transmission (Price included in the motor cost)
    B&M short shifter ($220)
    Side mount intercooler with corresponding tubing ($150)
    Cusco 10.56lbs chromoly flywheel ($400)
    Exedy Stage 2 clutch ($400)
    SPL clutch fork pivot ($40)
    New oem clutch slave cylinder ($20)
    New oem clutch master cylinder ($40)
    Bypassed clutch dampener box
    Hicas front steering rack (faster ratio than OEM rack) ($200)
    New outer tie rods for the steering rack ($70)
    Energy Suspension polyurethane bushings for the steering rack ($20)
    Greddy pulleys ($200)
    Greddy EGT Gauge ($200)
    NGK Sparkplugs PFR7G-11 (one step colder) ($50)
    Durdan Perfab wiring harness for the motor swap ($300)
    Koyo Aluminum radiator ($300)
    Koyo 1.3 bar radiator cap
    FAL 220 Fans ($250)
    Fal fan control unit custom mounted ($100)
    Walboro 255 fuel pump ($100)
    300zx rear parking brake assembly ($70)
    Ichiba 5 lug conversion hubs front and rear (new bearings included) ($500)
    300zx Front brake calipers 30MM Aluminum remanufactured and coated red (4 Piston - $300)
    300zx Rear brake calipers Aluminum remanufactured and coated red (2 Piston - $200)
    Brembo 300zx TT front brake rotors ($150)
    Powerslot 300zx rear brake rotors ($100)
    Ferodo DS2500 brake pads front and rear ($300)
    Stainless steel brake conversion lines ($80)
    300zx Brake master cylinder ($200)
    Remanufactured 240sx brake booster ($100)
    Russell speed bleeders on the calipers ($50)
    Motul RBF600 brake fluid ($70)
    Enkei RPF1 rims 16x8 + 15 offset brand spanking new! ($1000)
    Yokohama A048R tires. 205/50/16 brand spanking new as well ($800)
    Nardi 330 Deep corn steering wheel ($350)
    NRG short hub ($200)
    NRG Quick Release (Package price with NRG HUB)
    NRG Lock (Package price with NRG HUB)
    180sx Cluster. Amber lit. Speedo converted to read in mph. Tuned for new size rear tires and gears as well. ($100)
    S14 Manual seatbelt conversion ($50)
    Nismo thermostat ($70)
    New OEM water pump ($60)
    Samco Silicone radiator hoses ($100)
    New heater hoses ($35)
    Many hoses replaced for the swap
    New 02 Sentra 2.0L exhaust manifold gasket ($45)
    New turbo oil return gasket ($5)
    New turbo to o2 housing gasket ($5)
    New hotpipe outlet gasket ($5)
    New crush washers for the turbo oil and coolant lines from block to turbo ($5)
    Greddy 3" turbo elbow ($300)
    Greddy 3" downpipe ($200)
    Megan 3" testpie ($70)
    Buddy club spec 2 3" exhaust ($400)
    Circuit sport polyurethane exhaust hangers ($50)
    Cusco polyurethane motor mounts ($200)
    Peak performance race transmission mount ($70)
    Greddy shift knob ($30)
    Redlinegoods carbon fiber look shift boot. ($35)
    Enjuku racing hot pipe ($80)
    Greddy Type RS bov ($200)
    Apexi S13 air intake kit ($150)
    New pilot and throw out bearings
    Redline MT90 transmission fluid ($70)
    Redline 75w90 gear oil for the diff ($70)
    Aluminum GTO bushing (for the steering column) ($25)
    Blitz turbo timer (with built in boost gauge) ($200)
    New silicone couplers for the intake to turbo, and hot pipe to intercooler. T-Bolt clamps to go with them. ($100)
    New advance auto battery ($30)
    Redline water wetter/water mixture ($8)
    JDM front bumper lamps ($60)
    Some cheap carbon fiber piece that replaces the radio and is designed to hold 52mm gauges (no radio people) ($50)
    AC system removed.
    New hatch struts installed. ($50)
    Everything listed above is included in the sale of the car. I may of missed some parts still.
    Additional information:
    All work was done by me at home. I took tons of pictures and made posts. My username is bumnah. I'm on Club240, Fresh Alloy and NICO. Feel free to search my name for posts regarding the car.
    I took great care in putting this motor in and I took my time. I plan to keep the car if no one gives me the $ I'd like to receiver for putting it together. When I replaced bolts and nuts I cleaned them before reassembly so they would thread on nice and clean. I cleaned the inside the bell housing for an hour to remove as much crud as possible. I didn't rush the install, and I didn't cut corners. I bought name brand quality parts to get as oem as possible of an install.
    How the car runs. Perfect. The car vibrates as expected with the stiff motor/tranny mounts. She fires up nice and smooth everytime. Fully spooled by 2400 rpms. Pulls solid to the redline. I have put ~6000 miles on the motor since I got her running. No issues what so ever.
    3 problems I have found but don't plan to address:
    5th gear grind (common stuff on these motor swaps). If you do it slowly no grind, pulls fine. Syncro is worn out. From a motor from japan if this is the worst it gets I'm happy with it. B&M short shifter makes a noise. Again common stuff. It's minor to me since the whole car vibrates from the motor swap. None of these will hurt the car or ruin the fun in driving the car. Perhaps this is version 01. But I've heard version 02 doesn't make the noise. I dunno. Every RWD car that i've driven with a short throw shifter in the transmission made this noise.
    Reverse lights do not work. Only sensor plugged in is the speedo. None of the transmission plugs other than that are plugged in. I did that to bypass the speed limiter. You can plug it in and make it work.
    The car shoots fire out the muffler because of the vent to atmosphere BOV; easily fixed by having it vent back in the system.
    There is no emission equipment on this car at all.
    Asking price: BEST OFFER. There’s over $12k in parts invested already. NOT including the purchase of the car. I don't expect to get all my money back, but don't expect me to give this car away.
    Links to pictures:
    http://www.bumnah.com/swap (motor swap journal)
    http://www.bumnah.com/240 (car when I bought her in April of '06.
    http://www.bumnah.com/gto (gto bushing install)
    http://www.bumnah.com/brakes (brake conversion journal)
    http://www.bumnah.com/interior (steering wheel and seat belt conversion page)
    http://www.bumnah.com/futwerks (Enkei rims and Yokohama tire upgrades)
    Email me if you are interested. Again I'm in no rush to sell nor do I care if it does. I plan to move forward with other projects I have lined up for the car.
    Thanks for looking.
    Email me here: fourms at bumnah dot com
    Don't post if you don't plan to buy.
  2. #2
    Junior Member RotorHead's Avatar
    Join Date
    Aug 2008
    Location
    Thunder Bay Ontario
    Posts
    2
    trades?
  3. #2
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
