i have a problem with my car
sopme of you about 2 yrs ago my car was in an accident where it was rear ended pretty bad
it was fixed but every now and then when it rains i'll see it is wet in the trunk like there was a leak somewhere
it's rained pretty good these past 2 days and i just saw there is alot of water in there, not flooded but a good amt
what can i do?
what can i do?
check the seals, trunk could be miss aligned.
best thing to do is close the trunk, fold down the back seats get in the trunk have some one throw water on the car see where its coming from.
try to find where its leaking from. a straight body one should drain properly.
HA.net Workout Krew
It would take some investigating.. For now, use the shop vac and dry out the car. first check the trunk seals, then pull the rear panels/trunk panels. then check the rear deck and rear glass.
It's also a very good possiblity that the water intrusion is coming from the tail lights. Make sure the gaskets are good.
