| Track & Autocross Talk lap times and race lines. |
Thread Tools | Display Modes |
#1 | |||||||
GWAKS- Tech Geekifier
TECH: Car setup basics
-Harry AIM: NDcissive CRX and Pre '92 Civic, Engine Tech and Tuning, & Track and Autocross Forum Mod |
| Sponsored Links | ||
#2 |
Hellsing Agency
One thing I never understood is why the Japan FF road racers and gymkhana folk run spring/shock suspension setups that are OPPOSITE to those of us US folk. Higher spring rates in front/lower rates in rear, ESPECIALLY in gymkhana. One would think this would contribute to huge understeer.
Then again, running super high rates in the rear make the car prone to dive bombing and becoming squiggly under hard braking. Any thoughts on this? Shingo |
#3 | |
Quote:
In Japan, trail braking rules supreme. Drivers will drive into a corner as fast as possible, hit the brakes VERY late, and stay on them until they're ready to hit the power again. By driving in such a manner, they're getting almost the same effective weight transfer that US drivers are, which means they're getting about the same handling, but their corner entry speed is usually much higher, at the expense of a little corner exit speed, which is focused on here in the US. You may also notice that drifting is also much bigger in Japan than here, and so higher front spring rates play a huge role in that, but more for the reason of guaranteeing steering control with the car sideways, while allowing the car to remain sideways; which is difficult at best with a US prepped car once you apply the power again. |
#4 |
Meow?
In addition to what Harry said, some Japanese race cars run skinnier tires on the back to encourage rotation without transferring too much weight away from the front.
#5 | |
Re: TECH: Car setup basics
Quote:
, so if you don't mind I would like to discuss it. I know that more positive caster helps high speed stability and allows the steering wheel to return faster, but I was unaware of the weight transfer issue. If you don't mind, could you please explain the effects that caster has on weight transfer?TIA, Andrew '98 DX Sedan Sus. Tech. springs Extemely Conservative Mode- Frnt: -0.1*(L), +0.2*(R) Camber (3/10 Split to compensate for road crown here in Idaho) +1.8* Caster +0.05* Toe Rear: +0.9* Camber +0.12* Toe |
#6 | |
Re: Re: TECH: Car setup basics
Quote:
The easiest way to think about how caster works is to imagine a wheel and how it moves during steering, or, you can illustrate with a roll of tape on your desk. Using the tape example, use a rubber band or something sufficient to hold a pencil through the centerline of the roll of tape, orienting the roll like the tire and wheel would be. Now, during steering we all know that the wheel will turn left or right about it's steering axis, and this can be demonstrated by holding the pencil perpendicular to the table and twisting. Now, if we tilt the pencil back towards us and turn the wheel, what happens? Can't really tell can you? Do the same thing, and this time, hold the pencil with your other hand and hold the tape slightly above the table surface. What you should notice is that when you turn outboard, the wheel "digs in" to the table, and when you turn inboard to the pencil, it seems to lift slightly. Any time the contact patch of the tire changes it's "distance" up or down, it tries to carry or lose more weight. When the tape tries to "dig in" it's effectively trying to carry more weight, which is what you want for cornering, more inside weight for stability, especially since the natural tendency is for items of mass to travel to the outside radius. Now, if you do the same observations but this time tilting the pencil away from you, you'll notice that when the tape turns outboard, it tries to lift from the table. This isn't an entirely bad thing. The idea is for the inside to be forced to carry more weight by raising it's height, which will then catch the weight of the outside wheel as the front tries to re-establish an equilibrium. This normally means the outside tire takes a lot of abuse on corner entry, and that corner entry is a bit more squimish. This isn't entirely the front tire's fault though. What I haven't mentioned is the weight transfer effect to the rear wheels. Now, in an ideal chassis, the frame is absolutely rigid, and as we all know, if you lift on one corner, the weight has to be carried by another corner. This is where cross-weight comes into play in the grand scheme of cornering weight transfer. I hope I didn't go through that too quick, any other questions? |
#7 | ||
Re: Re: Re: TECH: Car setup basics
Quote:
Quote:
Thanks, Andrew P.S. I liked your visual with the tape and pencil, very creative. |
#8 | |
Honorary Moderator Alumni
Quote:
Sponsored by: KAM Racing Sports, Falken Tires, Progress Technology, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO! Autocross Help Page |
#9 | |
Quote:
#10 | |
Any answer to my FWD caster question?
Quote:
#11 | |
Quote:
#12 |
Sorry!
My apologies, I didn't mean to push you.
Take your time!-Andrew |
#13 | |
Re: Re: Re: Re: TECH: Car setup basics
Quote:
Now, the reason for so much rear caster on a rear wheel drive is because the chassis can use it more. The power is delivered at the rear wheels, so the more cross weight you can get to the wheel, the harder you're going to force the tire to work in your favor. Obviously this has some limits, but that's the basic principle. On a FWD car, obviously the power is not delivered at the rear wheels, so you really only need to get enough weight transfer to keep the rear of the car predictable. It's all about weight transfer and cross-weights for corner entry. |
#14 | |
Re: Re: Re: Re: Re: TECH: Car setup basics
Quote:
So if I understand you correctly, the MORE caster you have (more being greater than 0 weather it be positive or negative) the MORE weight transfer you will have (theoretically speaking of course )? Sorry for dragging it out, but I would really like to understand this concept. Thank you for taking the time to explain it to me.-Andrew |
#15 | |||
Re: Re: Re: Re: Re: Re: TECH: Car setup basics
Quote:
Quote:
Quote:
#16 |
1stGenCRXerThanks for taking the time to school me.
#17 |
More basic suspension info, please!
Thanks for doing this. Us newbies appreciate it.
For lowered cars, is it safe to assume that some type of adjustable camber plate is being used? Or better still, what is a typical ride height that would not require camber plates? Thx, Erik
-Erik |
#18 |
The buffer safe zone for most Hondas are 1.5-2.0" where you do not need a camber kit. ONe thing that will affect wear too is toe. Too much drop and if I remember right your car will toe in, that will cause tire wear just as bad as bad camber.
I've been dropped 2" for over a year and my tires have worn nicely. But I also autocross on them frequently scrubbing the outsides too.
#19 |
Thanks for the info.
Congrats on your Nationals win. I saw your car in Grassroots Motorsports, right?
-Erik |
#20 | |
Quote:
I'm advertising for the guy who did win Nationals. He just opened a shop.But yes my car was in GRM blue Civic Si.
#21 |
I notice that in my 4dr 93 civic that if I'm cruising down a gravel road at 80km/h+ my ass end becomes QUITE loose and I have learned howto drive with it doing that. Its not the coolest feeling, but I can live with it for now.
#22 |
how much should i lower my car?
i know nothing about camber ive only heard that u must put some sort of camber kit if u drop more than 2 inches.. i was thinking of dropping 1.75 inches.. is this a good amount to get alot of downforce and be able to hug the corners? |
#23 |
Lowering a car has no direct affect on downforce unless the underside of your car is channeled to make best use of the air that travels under it.
What it does do is change the center of gravity on the car so that the forces on the tires become more parallel to the contact patch. That said, camber kits for lowered cars are largely needed so that you don't get uneven wear characteristics on the tread. The amount you should lower your car depends on your car, spring rates, tires, and road surface. For an average street car, 1.5"-1.75" is fine, but if you don't get a good set of shocks, and don't balance your spring rates accordingly, your handling could actually get worse.
#24 |
i plan to get really good springs and shocks and a good suspension setup
upon asking around.. ive been recommended many things and here is my plan for my setup on my 98 civic cx h/b.. please let me know what u think: with my gs-r swap ill be getting a LSD tranny custom ground control springs koni yellow shocks energy suspension polyurethane bushings front and rear sway bar upgrades (any help here? i dont know much) front and rear upper strut tower bars (neuspeed?) front and rear lower tie bars (recommendations?) crossbar lower the car (im not sure to what height... what u recommend?) 15" konig helium wheels falken azenis tires i would like to build the car to handle very well at the track so i can destroy this prelude around here that is known for being fast on the track.. let me know what u think and if u have any concerns, critiques.. thanks |
#25 |
As we veteran racers always say the best money spent is on schooling - whether it be an HPDE (High Performance Driving Education) or Evolution School (autocross).
Spend $1000 on suspension mods and you might gain .5-1 second on a 30 second course. Spend $225 on an Evolution School and you can drop 4-10 seconds off the same course. Schooling is much more cost effective than spending money on mods.
#26 |
i also plan to get some schooling ... but any feedback on that setup?
#27 |
If you didn't get it then hold off. And just do the schools. Believe me you will be faster without the suspension setup.
#28 | |
Quote:
Are you sure you don't know trailbraking USDM drivers? I know: * NASA instructors who teach FF trailbraking techniques to upper level Group 2 drivers, and Group 3 drivers who ask them along. *Some very successful Honda Challenge drivers (including the H1 and H2 champions in '02), who trail brake as a matter of course. Having observed the Spoon Sports #96 car up close, and having talked to Ichisima about the differences between USDM and JDM racing setups, the biggest difference physically seems to be that the JDM drivers run more extreme camber settings (negative) on the front, and have bigger swaybars on the back of the car. When everything's said and done, the JDM and USDM cars appear to have the same handling dynamics, but they achieve it differently. The USDM way is cheaper, which is a consideration for students. A couple of years ago, I bought Spoon springs (heavy front) for my ITR, without really telling anybody I was doing it or consulting anybody. They were a little upset w/me because simply buying the springs, and knowing the purpose I had in mind, they felt this was detrimental and they'd be getting bad publicity for it. It really didn't do what I wanted, and in getting suggestions for sorting it out correctly, AJ Racing (Spoon distributor for North America) advised me that -2.5 negative camber on the front would be a part of the solution. ![]() I'm now on revalved Koni Yellows, 400# springs front, 500# springs rear, and the car's a delight to drive on street or track. Swaybars OEM. It fits perfectly into NASA Group 3 but it can still be driven to and from the track in complete comfort. I have heard the comment about JDM-exclusive trailbraking before, and I'm not really sure where that comes from. Perhaps it has to do w/all the videos we get from them, which videos have a little screen focused on the pedal activity. I think that most of the people who watch those tapes are not at a developmental stage where they'd be considering trailbraking in an FF car, and they're not at a stage of development that their instructors are comfortable talking to them about it. So they continue to believe that it's a JDM characteristic. I watched the RealTime DC2 cars in the only World Challenge race I've seen at VIR Full, and those guys were definitely trailbraking.... Definitely. LOL... Personally, with my setup, I trailbrake a little, but it's not extreme, since I'm out there to have fun and fully intend to drive the car home and not spin out in front of the Cobra I just passed on the straight. ![]() Example I can think of is Summit Turn 5. If your lap times are faster, you can get by some very fast cars between Turn 4 and Turn 5, but you'll be faced with having to slow down from 110 to 45 very quickly. An ITR will be borderline ABS even on good R compounds w/that manoeuvre, and you'll have to trailbrake into the turn to control it. If you time it right, you're on the gas again right when you get to the apex and the Cobra or Porsche driver is mentally scratching his head wondering how you did that. As the years go by, it seems that more and more USDM racing outfits are using the JDM heavy nose setup but with heavier bars in the rear and radical camber up front to make up for it. Although I'm not at the stage of development where I'd want to start over w/a different suspension, I know there's got to be something to it. I believe that Jason Franza, the ECHC H2 champion in '03 has a heavy nose setup. That refers to the DC2 people. I've noticed that all the DC5 and EP3 people seem to agree on heavy spring rears. Even the Mugen Street setup (on my daily driver EP3) is heavy springs on the rear.
Commonwealth Foundation || www.george.knighton.com || DVX.ET.FID.DEF Folkets kaerlighed, min styrke |
#29 |
George, I know how to trail brake, and maybe my definition of trail braking differs a bit from yours.
To me, you're describing when a late braking manuever turns into a necessary trail braking situation. Most ECHC guys I've seen fall into this category, but the majority of their braking occurs with the wheels as straight as possible. When I trail brake, braking doesn't even begin until AFTER turn-in. Sure, the driver has to lift off the gas a little earlier, but actual braking doesn't start until you've already started your initial turn. Most FF cars suffer an aburpt trip to the gravel trying this .The additional camber in the front plays a big role in how much you can get away with trail braking, in any car, because of weight transfer. As you turn in, the tire starts flattening, and then once you apply the brakes, the forward outside corner really dives down and takes a lot of weight. A tire nearing zero camber is going to roll over and send you again, to the gravel. Of course, to get the greatest benefit from this without excessive body roll, you need some stiff springs, and you can get away with lighter springs in the rear for rotation under braking. I've had a chance to talk with drivers from around the world from my living room [internet is great that way], and in my travels been able to talk with regional drivers. There's lots of ways to be fast, but it's all about comfort.
#30 | |
Quote:
That's about all I have to say about that. The track corners that I'm aware of, it would be hazardous to even think about that. It's hard enough doing it my way, and I think that at my stage of development it would be impossible. In the specific Summit Turn 5 manoeuvre I mentioned, it would be patently impossible to slow from 110 to 45 if you're already turning. We'll have to get together at Summit or VIR sometime and compare notes.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
