i need help guys
Mr. Motorhead
i need help guys
i just took the cam out of my car and did a compresson check. did it this way to see if any valves were bent. 1st cyl 58lbs
2nd 26 3rd25 4th 25....tells me that something seriuosly wrong...right? so i decided to pull the head off, 45minutes later i check the head....i do the wd40 down in the head trick to see if any leaks through to the combustion side...and guess what...NO LEAKS.could i still have bad valves? there is no indication that the valves hit the pistons.i am lost...please help? it is a 97 civic dx with 74,800 miles on it.
hey man, if you put it in a different forum you will get more responses. This is for sale forum. Either put it in mechanic forum or civic forum. Good luck on fixing that problem.
