Endlinks are fux0r3d, suggestion?
I got worms.
I figured that it was on account of the endlinks that the sway bar was rattling, but I didn't expect this. I have the old Comptech rear sway, what do you guys suggest I do?
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
The deer had to die!
i have the new Comptech Sway/Tie-bar setup. It also came with adjustable endlinks - they also rattle slightly. I've read of people getting the OEM rubber endlinks to minimize the rattle, but like all rubber things, they deteriorate. Just get new endlinks from Comptech. They should supply them for a relatively low price.
I got worms.
From what I've gathered, these endlinks use a spherical joint and no bushings. I believe that I'd need to replace both parts? Even with new endlinks there will still be excessive rattle?
99 Integra GSR
06 TSX
99 Integra GSR
06 TSX
yes, the comptech endlinks utilize a spherical joint. replace the male/female units for brand new.
about the rattle, i BELIEVE its because i may have the endlinks adjusted too long. the directions from comptech say to set them 3-1/4" apart. however that is for the soft setting. harder settings require a longer distance between the joints.
I got worms.
99 Integra GSR
06 TSX
99 Integra GSR
06 TSX
I got worms.
true...just get new Comptech endlinks, Chanc!!!!
99 Integra GSR
06 TSX
99 Integra GSR
06 TSX
Whats so fuxored about them chanc? I cant tell from the pictures, but did the spherical bushing fall out or break?
DB Squad
Integra Forum Moderator
DB Squad
I got worms.
99 Integra GSR
06 TSX
99 Integra GSR
06 TSX
