Changing spark plugs (easy)
Old 08-19-2003, 09:54 AM
shawmutt
shawmutt's Avatar
Default Changing spark plugs (easy)
I feel like a complete idiot, but I need to change my plugs, and I can't figure out how to get the wires off to access the plugs. I pulled and pulled, and only succeeded in pulling the boot off. How do I get the wires off to get to the plugs???
Old 08-19-2003, 11:40 AM
crxb16er
crxb16er's Avatar
twist the wire out of the spark plug hole
Old 08-19-2003, 11:41 AM
crxb16er
crxb16er's Avatar
then use an extension and spark plug remover and unscrew the spark plug from the head, lefty loosey righty tighty
Old 08-19-2003, 11:59 AM
shawmutt
shawmutt's Avatar
Does it pop right off or is there a particular way to twist?
Old 08-19-2003, 12:25 PM
crxb16er
crxb16er's Avatar
it does pop right out but a little twist helps it out sometimes, just yank on the spark plug boot not the wire or else u can damage the wire if u yank really hard, its like a vacume cleaner plug u can just yank it out but its not suggested
Old 08-20-2003, 10:15 PM
Kai
Rotorphile.
Kai's Avatar
It sounds like the wire is corroded to the plug. This is not good, however easy to fix.
Step 1) Grab the plug wires with vise-grip pliers and rip them off.
Step 2) Unscrew and remove sparkplugs.
Step 3) Replace the plugs and wires with new, quality parts.
YMMV, be gentle as nessicary.
Done.:thumbup:
Old 08-21-2003, 06:47 AM
zang42
zang42's Avatar
use anti-seize on the new plug threads... and torque them down properly or ask someone how to estimate torque if you don't have a torque wrench.
Old 08-21-2003, 09:44 AM
shawmutt
shawmutt's Avatar
cool thanks, I'll try it tomorrow
Old 08-22-2003, 11:24 PM
Technodigifreak
Hot-Modder
Technodigifreak's Avatar
well, if your doing plugs, chances are your goin to want to do a few other things to your vehicle, now is a good time to invest in a quality torque wrench
Old 08-23-2003, 06:04 PM
LSVTECKING
rebuilding
LSVTECKING's Avatar
Definately dont put anti-seize on you plugs. ANti-seize is not made to handle temperatures that high it will melt and get so damn hard you'll have a harder time geting them off then your having right now.
