XLR Bixenon projectors + bulbs, Philips ballasts and wiring
Old 01-26-2012, 04:18 PM
mayonaise
mayonaise's Avatar
Default XLR Bixenon projectors + bulbs, Philips ballasts and wiring
2.5" Bixenon projectors from a Cadillac XLR. I pulled these out of a crappy retrofit I bought. The guy I got them from did such a shitty job I just had them sitting in my garage forever. I finally pulled them apart and salvaged these. I believe the bulbs are D1S.
The projectors are in great shape. They come with ballasts, bulbs, and wiring. The projectors are big and come mounted to these wide plastic brackets, which also holds the high/low-beam solenoid. If you don't want the bixenon you can lose the bracket. The brackets have some holes drilled in them already from the retrofit. I'm guessing you'd have a hard time retrofitting these into a 5th gen if you have ABS.
Projectors: $100
Bulbs: $30
Ballasts + wiring: $100
Everything together: $200
