Import Builders Block Need Opinions!!
Old 08-09-2003, 11:20 AM
mishima_beef
mishima_beef's Avatar
Default Import Builders Block Need Opinions!!
PACKAGE 7: IB Sleeved "Killer" GSR B18C Block
Description: "I want the best." This is Import Builders favorite block. It revs higher and has slower piston speed, slightly than its B18A/B cousin. This block features the following details:
Iron Sleeves for total strength and durability
IB Spec Wiseco Pistons, JE pistons, or Arias Pistons. You choose!
Eagle Rods or Probe Rods
Bore, Hone, Hot tank, Deck (if nec)
Balanced Crank
Polished Crank
All new Bearings & Thrusts
All new seals, and Oil pan Gasket
New VTEC oil pump
New VTEC water pump
LS/VTEC Oil line Kit with all fittings
Compressions come in 9:1, 9.4:1, 10.5:1, 11.8:1, 12:1, 12.5:1. 12.8:1, 13:1
Price: $3950 Shipped. Want to rev it to 9600 RPM all motor? Pick this one.
what do u guys think about this deal?
i would either get the 10.5:1 compression and go n/a or get the 9:1 compresion and get a big turbo
