F/s: OEM BMW HId Bi-Xenon Projectors High and low beam!
EBAY: http://cgi.ebay.com/ebaymotors...60894
these projectors will provide you with high and low beam HIDs!!!
the little motor in the projectors moves the shield when your high beams are activated. All the wiring involves is connecting your pos + and neg - wires from your high beam to the pos + and neg - coming from the projectors. EASY!!
here are the pics:
GET OEM hid's TODAY!!!
Use these for a retrofit in your integra/civic, whatever!
These projectors use regular D2S bulbs, no need for rebased bulbs!
Price : $150
here are the pics:
Price : $150
i believe they are the same size and shape as the X5 projectors, these just have the high and low beam function
X5 projectors (i used to have these as well)
let me know guys
let me know guys
you do not need the X5 hid system to get the same lighting. the projectors are the main reason why x5's have that super bright light output. Once you have the projectors, you can use any factory hid system to get the same look
you will want to buy a factory hid system w/ d2s bulbs out of a acura, BMW, audi, whatever you can find (these are cheaper than aftermarket kits because they do not use rebased bulbs) you can typically find a set for around $200-250
cutoff line with a single led light in the projector!!! look how distinct it is and the color with only a single led pen light
cut off line:
cut off line:
