How To: Clean Your Throttle Body
Old 07-26-2003, 08:48 PM
b12uceHuy
Jizz Maste12
b12uceHuy's Avatar
Default throttle body CLEAN
just cleaned my throttle body today for my 6gen accord
You will need:
-Screw driver
-1 can of Sea Foam
-a Can
-a baseter tube or funnle tube
-a straw (from a sports bottle)
This is the engine bay
Your throttle body is connected to your intake
you want to remove it by using your screw driver, then you will stick the straw into the throttle body plate inside
It should look like that with the intake removed
you can stick the tube in to the TB
Old 07-26-2003, 08:52 PM
b12uceHuy
Jizz Maste12
b12uceHuy's Avatar
It should look something like this, you can pour the Seafoam into the funnel slowly 1/3 of the can your engine should choke and cut off you'll also see smoke coming out of ur exhast, once you finish pouring the SF into the intake let your car set for 5mins then start your car and go for a ride WOT.
start your engine and step on the gas a little
POOF a shit load of smoke will come out
Time for you to get in to your car and go WOT around the block maybe even a trip on the freeway.
Do this a couple of times
Old 07-26-2003, 09:55 PM
kaliraver69
kaliraver69's Avatar
Sorry for asking a noob question but where is that throttle body plate in the pix? If it'snot visible can u post a better pix of it.
Old 07-26-2003, 10:03 PM
b12uceHuy
Jizz Maste12
b12uceHuy's Avatar
the trottle plate is INSIDE the throttle body you have to use your finger and push the straw in, its difficult to take a picture of it. Looks just like a carbator but sideways.
Old 07-26-2003, 10:13 PM
kaliraver69
Hmmm that kinda helps. Oh well I just don't know how do you get that place in the first place. Do you have to remove the intake or what?
Old 07-27-2003, 09:44 AM
pirate252
pirate252's Avatar
great idea with the straw, for some reason i didnt think of that, and just used a turkey baster to inject it in, while pulling a little on the throttle cable, spilled a lot of shit all down in my engine compartment, hope it doesnt hurt anything
Matt
Old 07-27-2003, 10:10 AM
b12uceHuy
Jizz Maste12
b12uceHuy's Avatar
Matt
your lucky your car didnt catch on fire lol
Old 07-27-2003, 01:13 PM
firebane
firebane's Avatar
hmm I've been trying to find that Sea Foam but my local NAPA store doesn't carry it!
Old 08-07-2003, 09:36 AM
carbon-vtec
carbon-vtec's Avatar
i just use a can of stp intake and throttle body cleaner from autozone
Old 09-19-2003, 10:13 AM
uclaccord
uclaccord's Avatar
how exactly would sea foam clean this all up...never heard of sea foam
