High gear on low speeds?
Old 07-20-2003, 12:06 PM
FoB616
FoB616's Avatar
Default High gear on low speeds?
Hey I was wondering, if driving on a high gear (5th) at low speeds (like 20-25mph) will mess up my transmission in the long run.
I try to shift up asap cuz higher gear = saves gas.
However, I'm just worried that whenever I hear this little grinding noise, it's messing up my tranny.
Old 07-20-2003, 12:34 PM
Kai
Rotorphile.
Kai's Avatar
No.
However, it's not supposed to grind, either.
Old 07-20-2003, 02:25 PM
DMA94ls
DMA94ls's Avatar
Integras are good on gas regardless.
Put it into 4th and thats good enough
Old 07-20-2003, 03:13 PM
thx247
thx247's Avatar
5th gear at 20mph is going to bog the engine down, I would not worry about it. shift at 3k, dont punch it at starts, use the brakes as little as possible. You should get 26+mpg
Old 07-20-2003, 03:36 PM
98grnLS.
98grnLS.'s Avatar
its alright to cruz in fifth just as long as your not gonna punch it or try and accelerate, by punchin it your gonna suck gas, but im in fifth all the time, just cuts down on teh noise from the muffler.
Old 07-20-2003, 06:36 PM
mrhonda_187
mrhonda_187's Avatar
You like to pedal your bike in the hardest gear? Same thing... Pick a gear that the motor is comfortable with, and you'll be fine.
Old 07-20-2003, 09:03 PM
b00gers
b00gers's Avatar
higher gear DOES NOT mean better gas milage.
try entering a freeway on ramp from a stop starting in first gear and shifting to 5th at 20mph. the amount of power (gas) needed from the engine to bring the car to speed at such a high gear will be more than the power (gas) needed doing the normal, 1-2-3-4-5 shift.
you just have to find the right compromise and know when to shift. but like someone said...tegs are good with gas anyway.
Old 07-20-2003, 09:15 PM
95tegRS
95tegRS's Avatar
you strain your engine alot!!, 5th is okay for 45 mph+
Old 07-21-2003, 03:31 PM
DB7 2.0
Banned
DB7 2.0's Avatar
you need to get an auto
Old 07-21-2003, 08:51 PM
ADRteg
ADRteg's Avatar
something is wrong with my car, i used to get 300 miles per tank, not i'm only gettin 250, its no good
