Installing A Strut Bar?
Old 07-18-2003, 09:03 AM
IamNemo
You know me...
IamNemo's Avatar
Default putting a strut bar on?
Ok...I'm gonna sound like a moron, but when putting a strut bar on do you just take the nuts off of the strut, put the bar on and put the nuts back on...and then do the same to the other side? I just don't want to screw anything up So I'm trying to be extra careful.
Old 07-18-2003, 11:39 AM
whoaitslen2
hermit
whoaitslen2's Avatar
yeaup
Old 07-18-2003, 02:12 PM
LX4CYL
Cone Basher
LX4CYL's Avatar
you might have to jack the car up if the bolts are hard to remove, and don't line up.
Old 07-18-2003, 11:27 PM
b00gers
b00gers's Avatar
yes. its that simple. good luck.
Old 09-04-2003, 09:12 PM
Big Chaze
Mr Clutch
Big Chaze's Avatar
Shouldnt the nuts be torqued???
Old 09-05-2003, 09:10 PM
Technodigifreak
Hot-Modder
Technodigifreak's Avatar
yeah its that stupid simple, and as far as i know there is no torque specified for the nuts on the strut mount
Old 09-07-2003, 05:01 PM
johnnybravo
johnnybravo's Avatar
Default Jacked up....
Would too much tension be put on the strut bars if you lift the car on a jack and then apply the bar? I mean lifting it up would release tension long enough for the application sure, however when the car is back on ground it would have to handle a lot of stress not to mention performance driving? Best explanation......
Old 09-09-2003, 05:33 AM
Civic Type Sev
Civic Type Sev's Avatar
If you decide to jack up the car for installation... it will relieve the stress on the frame and then when you lower it again with the bar; the bar will be pre-compressed which will make your car even stiffer. That's what I did when I installed mine.
Note that for this to work you have to jack up the car from the centerline and this can be quite unstable. If you decide to not jack up the car from the centerline and use the regular lifting points on the sides you might as well not lift it up at all since the frame will still be loaded.
Hope this helps.
Old 09-09-2003, 10:08 AM
IamNemo
You know me...
IamNemo's Avatar
Considering I put the strut bar on around....oh.....2 months ago...I was just wondering why people were still replying to this post!
Old 09-13-2003, 02:06 AM
Big Chaze
Mr Clutch
Big Chaze's Avatar
Cause I came across this thread, and I asked if the nuts had to be torqued.
ISnt that what the search tab is for???
