oversteer with civic?
Where am I?
I have been driving my civic for a couple of months now, and i have noticed that the car tends to oversteer easier than any other FF cars that i have ever driven. I like it, though. It makes the car fun to drive, but a little hard to control at times. I actually did a drift with the car when autocrossing-without using the ebrake at all. It is fairly easy to control-most of the time, but i think i made it worse by adding a rear tower bar. The car has no other susp mods, other than a front tower bar from a 2000 si. It has the 70 spec 13's still, with no intent on changing them for any reason, other than to look pretty :naughty:
-To clarify, it only occurs when most underpowered cars oversteer-off throttle or during braking
What changes can i make that would allow the car to keep this oversteer quality?
I already have a set of neuspeed sport springs in the closet, and i am considering some oem sway bars, and some bilstein HD or Koni adj struts. I am planning on making this a competition-ready street car. I want it to still be driveable on the stree, but will allow me to go to track days and autocrosses without worry that it will perform to its fullest
One more thing: The car now has 256k on the odo. I am gonna buy a master bushing kit from energy suspension to help steady everything. would this hurt the o.s. issue??
it's my D in a B
your oversteer could be at least partially caused by bad bushings. When I bought my car @155k miles, it oversteered also... but was quite sloppy and detatched. A master bushing kit is a good idea and will dramatically improve your handling, but wont really help you keep that oversteer. Your springs will also be a bit understeer biased. those alone will probably kill the oversteer youre experiencing.
GWAKS- Tech Geekifier
You can do all your suspension mods and then just use mis-matched tires, some stickies up front, and some super mileage tires in the rear. :rick:
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
I am currently using this method.
If you wanna get your rear end to slide around in turns it works very well.
That's what alot of Japanese racers do in their "hill climbs" with their fwd cars.I sold my Neuspeed race springs because I couldn't get my car to oversteer at all.I went with coilovers,not that my other springs were bad but I've got more options now.I have suspension techniqes sway bars front and rear ,and I had to disconnect the front in order to get some oversteer action.I've got it where I want it now even though I've heard mixed opinions on diconnecting sway bars.Another thing is that I cranked up my rear shocks as high as they would go and left the fronts.You could also try playing with tire pressure,camber,etc.Your new bushings will definetely change the atttiude of your car.
so are u guys saying a car with oversteer is better?
so in actual fact its better to run (for example) 2 azenis in the front and some shit in the rear than 4 azenis?!
