clicking sound in distributer
Old 07-16-2003, 02:50 PM
spooncivicb16b
spooncivicb16b's Avatar
Default clicking sound in distributer
my lil' bro's 94 rs has kind of a clicking sound in his distributer sometimes what should we check?
Old 07-16-2003, 02:52 PM
b00gers
b00gers's Avatar
what does the click sound like? are they fast? and how loud are they? when do you hear it?
Old 07-16-2003, 02:53 PM
spooncivicb16b
just at idle , its loud enough to hear with the hood closed but not really loud to be annoying
Old 07-16-2003, 04:23 PM
MikeR
MikeR's Avatar
and your sure it's coming from your dist.? not to doubt you but your sure it isn't valve lash?
Old 07-16-2003, 04:40 PM
jfiedler
Junior Member w/Fries
jfiedler's Avatar
if the cap & rotor are worn, you could actually be hearing a spark bridging inside the distributor.
Old 07-16-2003, 05:29 PM
b00gers
b00gers's Avatar
are you sure its from your distributor? because other things click under the hood, such as the injectors which can click pretty loud.
or you may even need a valve adjustment.
Old 07-17-2003, 04:43 AM
90'RS
90'RS's Avatar
I just recently had a clicking noise from the distributor also and when I took off the cap I realized that my wires running to the coil were loose some how. I doubt this is what is wrong with your car but if it happened to me it could happened to others. While in there go ahead and check the cap and rotor and replace an necessary.
Old 07-17-2003, 09:16 AM
spooncivicb16b
i don't think he needs a valve adjustment cause it doesnt sound like the valves. we also put ouer ear up to the ditributer and we are sure its coming from there.
Old 07-17-2003, 09:00 PM
newgsrdriver
newgsrdriver's Avatar
Take off the cap and make sure the rotor is on correctly. Also check to see if the screw backed out accidentally.
Old 07-22-2003, 06:49 AM
ThaJazz
ThaJazz's Avatar
I had noise from my 91 distributor and within a week that sucker almost killed my engine. CEL came on, car lost power, backfired, the whole nine. When I took the cap off, I had all kinds of brown dust. The squealing was from the rotor getting slowed as it turns.
I got a used distributor off my parts car and no problems since. By the way, NAPA has the best prices on used distributors--$129 w/ tax for my year. HTH
