Best front upper strut tower bar?
Old 06-18-2003, 01:26 PM
skot
skot's Avatar
Default Best front upper strut tower bar?
i just wanted to get some actual user opinions..
which do you think the best strut bar is?
skot is offline
Old 06-18-2003, 01:44 PM
lil_1_2002
lil_1_2002's Avatar
neuspeed by far the best i've seen and tried.
lil_1_2002 is offline
Old 06-18-2003, 02:12 PM
jschmid
jschmid's Avatar
What year is your Accord?
jschmid is offline
Old 06-18-2003, 02:33 PM
accordhybrid
accordhybrid's Avatar
REally doesn;t matter neuspeed is the best for all years
Accordhybrid
accordhybrid is offline
Old 06-18-2003, 02:35 PM
skot
skot's Avatar
its a 2000 4dr.
i was thinking about going with neuspeed. for some reason i just like their design. if i had the $$ id get a comtech titanium..
skot is offline
Old 06-18-2003, 02:48 PM
Fred Cook
Fred Cook's Avatar
Neuspeed Polished
Fred Cook is offline
Old 06-18-2003, 03:12 PM
jschmid
jschmid's Avatar
Originally posted by skot
its a 2000 4dr.
Yeah, if you are going for looks, go aftermarket, but if you just want function, get an Acura TL-S bar, it has two attachment points and bolts right in for ~$50
Mine:
jschmid is offline
Old 06-19-2003, 07:23 AM
skot
skot's Avatar
the way that tl-s bar is designed, it looks like i have to remove the existing angle brace that mounts to the tower and the chassis and bolt it on to those mounts.
how is the tl-s bar better than the neuspeed + existing angle braces?
is it because the cross bar is welded to the angle braces so the body roll gets dispersed to the chassis better? if that makes sense.
hmm.. one more thing, on a 2000 since its a fairly new model, is it worth replacing the anti roll bars,front and rear, (like the one in your pic). are the aftermarket ones really better than factory?
skot is offline
Old 06-19-2003, 08:30 AM
LX4CYL
Cone Basher
LX4CYL's Avatar
makes sense to me!
The Neuspeed is a good bar in itself, but for the 6th gens you can't just ignore the Acura TL-S/CL-S bar. I think the regular TL/CL get's that bar too. Anyways, it's possible to add the Neuspeed bar on top of the Stock Acura bars, so I guess it's possible to do in an Accord :dunno: :
http://www.cardomain.com/member_page...=184466&page=5
Again, you can use Acura TL-S/CL-S sways...
I wish I could buy the suspension stuff NOW!
LX4CYL is offline
Old 06-19-2003, 08:37 AM
jschmid
jschmid's Avatar
On the strut bar, the TL-S does what it's supposed to, increase rigidity. Can't really go wrong for $50.
On the sways, yes, aftermarket sways like eibach, etc will increase handling because they are thicker than the stock ones. Sway bars are actually large springs, so the thicker it is, generally the stiffer it will be and will increase handling.
For a moderate and cost effective increase you can just get the TL-S rear sway for $50 to beef up the rear and make the Accord handle more neutral.
jschmid is offline
