5th gen idle??
"you wanna die??"
ya mine idles at around 800 too. You sure your car is warmed up yet? Cuz when you first start the car it does idle at around 1500, then goes down after the cars warmed up.
cause it's tight!
Re: 5th gen idle??
Damn, most of you have a high idle. Mine idles between 600-800 when warmed up. I want to adjust it up to 800-1000 but anyone ever tried adjusting the idle? It's a pain:angry: The bolt you have to turn to change it has the looks of a flathead, but the slot on it is so shallow you can't get a good grip on it w/the screwdriver, not to mention there is some kind of wax seal over it to keep it in place.
Re: Re: 5th gen idle??
Forgive me... I'm a lexus guy who has a g/f and a best friend with accords, so I don't know if what I'm saying is true, but if 5th gen Accords are like lexuses and have electronically controlled throttle-bodies (I believe my friend's 03 Accord does but I could be remembering wrong), then the reason it's so hard to turn is because what you're trying to adjust is called the idle screw and is not supposed to be turned... it's really just a backup mechanism to use as a last resort in place of adjusting the fuel map / idle control.
Basically your car's internal programming monitors many different things and determines the best idle for you. That screw is a manual override, but it tends to cause many more problems than it fixes simply because it confuses the computer. The computer will then think that it's setting your idle at xxx RPM when in reality you're idling xxx RPM higher.
