18x7.5 and 40 offset, look good on accord coupe v6??
Old 06-13-2003, 12:08 AM
skyterri
skyterri's Avatar
Default 18x7.5 and 40 offset, look good on accord coupe v6??
is the offset ok?? what do u guys think? i have a 99 accord coupe v6
any input is appreciated
Old 06-13-2003, 05:24 AM
t-rd
t-rd's Avatar
That offset is too low. Go at least 48mm+
Old 06-13-2003, 05:27 AM
jschmid
jschmid's Avatar
Yeah, 40 is a bit low, but 45 will be perfect. I have 18x7.5, +45 offset, no rubbing. You can survive with 42 or 43, but I'd say 45 or 48 would be better.
Old 06-14-2003, 01:06 PM
V12Power
V12Power's Avatar
No 40mm is not to low. That is exactly what I have on my 2003 Accord V6 coupe w/ 18 x 7.5 and 235-40-18". They fit perfectly for the car! They came from discount tire.
Old 06-14-2003, 09:38 PM
99aznaccord
99aznaccord's Avatar
Isn't that a tad bit too wide of a tire? I have 225/40/18 and those still stick out a bit but still perfect. Anyways....I also have 18x7.5 with +40 offset and they fit fine, but I have a sedan so I'm not sure if it's the same or not. After I lowered the car, I was afraid of rubbing like crazy, but I only rub IF I have like 3 people in the back WITH my system and I hit a bit bump like a pothole or something with no one in the back. But I do wish I had like +42 or +43. If you can go higher, go for it, but if not, then don't worry TOO much about it.
Old 06-15-2003, 03:14 PM
swab
swab's Avatar
i just ordered 18x 7.5 konig prophet 45mm offset. heard that was a better offset then 40. So glad I did not order from discounttire, there prices are horrible. they wanted 108$ extra per wheel and 35$ more per tire but I got 225/40/18 kuhmo's comin too.. Can't wait.. jschmid: what springs you got? I got a eibach pro kit...
Old 06-15-2003, 07:51 PM
jschmid
jschmid's Avatar
I have H&R sports 1.75F, 1.5R. Since that pic in my sig was taken, I've lowered the front .25" more with my koni yellows.
BTW...Discount will match prices.
Old 06-15-2003, 08:51 PM
Illusion-Lighting
Illusion Lighting
Illusion-Lighting's Avatar
your offsets fine. i use to run 38+ w/ 18x8's. really aggressive standing look. you'll be slickly tucked w/ your setup.
Old 06-17-2003, 02:37 AM
AngryNerdRock
this space for rent
AngryNerdRock's Avatar
i've got +45 w/ 18x7.5 rims. that's what a lot of people recommended to me. and a lot of accord owners have that setup for 18's.
