can 9006 bulb be modified to fit in the 9005 socket?
Old 06-12-2003, 10:52 AM
figo07
figo07's Avatar
Default can 9006 bulb be modified to fit in the 9005 socket?
Can it?
Old 06-12-2003, 10:54 AM
yes ... it should just fit in.
Old 06-12-2003, 12:32 PM
figo07
figo07's Avatar
so i just can buy 9006s and fit them into AV6 lowbeams?
it's not gonna cause any wattage problem?
Old 06-12-2003, 12:58 PM
DriftKing
DriftKing's Avatar
they will melt the socket. the higher wattage makes it much hotter.
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
that should help
Old 06-12-2003, 01:08 PM
Cosmo M3
Lurker
Cosmo M3's Avatar
cut or melt the two guides inside the socket in order for it to fit
Old 06-12-2003, 01:09 PM
whoaitslen2
hermit
whoaitslen2's Avatar
silverstars wont melt your harness
Old 06-12-2003, 01:10 PM
Cosmo M3
Lurker
Cosmo M3's Avatar
:werd:
I don't think most 9006s will
Old 06-12-2003, 02:07 PM
TypeSH
TypeSH's Avatar
huh? 9006 draws less wattage than 9005. why would you want to do a backward conversion anyways? not to mention the 9006 has the cap on the tip of the bulb.
Old 06-12-2003, 03:59 PM
figo07
figo07's Avatar
AV6 has 9005 Lowbeam, and 9006 HighBeam, don't they?
then how come you say 9006 draws less watt?
Old 06-12-2003, 04:09 PM
jfiedler
Junior Member w/Fries
jfiedler's Avatar
Default got it backwards probably
they probably have 9006 lowbeams and 9005 highbeams. 9006 bulbs have the painted cap over the end. also, 9006 is lower wattage, not very good for high beam.
the two sockets (low/high) are not the same, there are little tabs in different locations around the ring to prevent you from accidentally putting the wrong bulb in. you'd have to cut into the housing with a dremel or a file or somethin. also, the electrical socket is different...one has a single tab and one has two tabs.
