70k miles now what?
70k miles now what?
i just reach the 70k miles what are the regular stuff parts that i'm supposed to change/replace, so far i have only change the brakes and oxygen sensors which is like every 60k since new heh now i'm thinking belts, water pump anything else because i wanna do all at once, and lately when i turn off the car there is this little black thing i can read what is says to gas tank it makes noise like if it had a fan inside spinning goes for seconds again then again then goes away i wonder what it is i will take pics to be more specific thanks. accord ex 96 vtech
Performance isn't $$$
change all belts, water pump and seals, also do the regular tune up which is spark plugs, distributor cap, distributor rotor, pcv valve, fuel filter and air filter and you should be good to go.
damn my car doesnt feel like its broke in yet and i'm in the low 70k's but then again most of my car has be swapped out in the years i've owned it. you should be fine,
Originally posted by decibel_dj
your car is fine.. my car needs a "blessing" to save her from the junk yard's crusher
Originally posted by vtecaccord01
when did you buy the car and how many miles was on it?
I picked her up on Halloween of 1998 as an early 1999 model, and she had 100 miles on her because the dealership had to get her from another dealer in upstate New York...
