Washing the Engine **Pics if Possible**
Old 06-07-2003, 07:16 PM
mrbrace
Goldenchild
mrbrace's Avatar
Default Washing the Engine **Pics if Possible**
If someone could help me out with pics on what to cover up I would appreciate it and also intstructions on how you went about it...thanks
Mr. Brace
Old 06-07-2003, 07:29 PM
hype8912
Dr. Klaw
hype8912's Avatar
Not to be an azz, but there is a whole thread covering this. Do a search. It was pretty recent.
Old 06-07-2003, 07:52 PM
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
DIY forum
Old 06-07-2003, 08:25 PM
JJJ784
No Soup For You!
JJJ784's Avatar
very SIMPLE and very GREEN. at least for me.
Old 06-08-2003, 02:47 PM
Jngrbrdman
Obsessed
Jngrbrdman's Avatar
Try here for pics and a few instructions.
I don't usually cover anything. I don't just pop the hood and start blasting water all over the place either so there isn't much need to cover anything. The only place I ever spray water on directly is around the painted areas like the wheel wells and firewall. I don't use high pressure either. Use a good degreaser to loosen up the crud and then the water just rinses it off. Don't rely on high pressure to do the work for you. Use good degreaser and get your hands dirty. If you get your engine clean once really good then you don't have to worry much about keeping it looking that way. Just touch it up once or twice a month and it will be fine.
Old 06-08-2003, 05:39 PM
JJJ784
No Soup For You!
JJJ784's Avatar
oh! and use a tooth brush! it helps get in the crevices.
