Idle problems...
Old 06-05-2003, 09:35 AM
Aggressivemport
Aggressivemport's Avatar
Default Idle problems...
I have a 1997 Civic with a D16Y7 and yesterday I installed a JG Edelbrock throttle body. Now the car at idle revs from 2000 to 400 then back to 2000rpm over and over. What is wrong? Please help!
Old 06-05-2003, 09:51 AM
HouseofKolorEX
I get off on WD 40
HouseofKolorEX's Avatar
Sounds like your engine is being strained by something... like... it's having to work extra hard, then it takes a break. How long does it stay at one RPM for before it changes to another? Possibly a part of your wiring snagged on something? Just trying to help. :dunno:
Old 06-05-2003, 10:29 AM
WideBodyEK
Stage 3 Modified
WideBodyEK's Avatar
sounds like your fast idle to me
Old 06-05-2003, 11:19 AM
SpeedRacerEX-R
SpeedRacerEX-R's Avatar
Sounds like coolant. Did you route your coolant through your tb? Did you bleed the system?
Old 06-05-2003, 11:33 AM
zero grip
zero grip's Avatar
could be a couple of things.
1. check the IAC (idle air control)
2. check the TPS (throttle position sensor)
3. did you put the original tb back on and still have the problem?
4. pull the fast idle valve and check the spring loaded plate, it could be loose and could mess with your idle.
5. vac leak?
6. pull the ecu for 10 min or so and try again.
keep us updated and good luck.
Old 06-05-2003, 11:50 AM
onebadassdx
onebadassdx's Avatar
i agree with the fast idle
Old 06-05-2003, 01:17 PM
Cashis EG8
Registered Rota Dealer
Cashis EG8's Avatar
I got money on vacuum leak
Old 06-05-2003, 01:38 PM
Aggressivemport
We put the orginial back on and the same problem. Then cleared the ECU and everything was well. BUT.... (lol) it now idles at 1250rpm.
Old 06-05-2003, 06:16 PM
Cashis EG8
Cashis EG8's Avatar
I would try double checking everything that was touched during the installation process.
Good luck :thumbup:
