93 Civic Si Won't Start???
Old 06-04-2003, 07:41 PM
CivicSiR7
CivicSiR7's Avatar
Default 93 Civic Si Won't Start???
I purchased a 93 Si from an old couple. After a few months of having it, it didn't crank one day. I thought it was not having power so I jump start it and it didn't start. So next I thought it was the starter. Replaced it with one off my other civic I had. It still didn't work. I doubled check even triple check everything from the ECU codes (which there was no codes throwing at all), ground wires, wires to starter, fuses in engine bay, and in the car. Car still won't crank! AHHH! Hurting my head just thinking about it. I even tried to jump start it. But the odd thing is what my dad told me to do is, he told me to push start it. It worked, but when I shut the car off and try to crank it, it did the same thing NOTHING. But while I was driving around the block, it kinda sputtered like it wanted to shut off. Have any of you fellas ran into something like this?
Old 06-04-2003, 07:42 PM
flipped cracka
BOOM goes the dynamite!
flipped cracka's Avatar
does it have gas? :dunno:
Old 06-04-2003, 07:55 PM
CivicSiR7
CivicSiR7's Avatar
Yes, a half tank.
Old 06-04-2003, 08:25 PM
AP1dude
JDM WHORE!!!
AP1dude's Avatar
Take it and get it looked at....your going to more than likely.But thats just my input.:dunno:
Old 06-04-2003, 10:17 PM
frank
frank from canada
frank's Avatar
did the timing belt slip?
Old 06-05-2003, 07:44 AM
wilsel
wilsel's Avatar
When you turn the key does it turnover (try to start), or just do nothing?
Old 06-05-2003, 07:54 AM
purplx
purplx's Avatar
sounds like my problem.
it could be clogged injectors or something else.
i added one of those injector cleaners and it seems to start and stay on.
i've noticed with my car, if you try to start it and it won't, give it a little time and try it again it may crank up.
Old 06-05-2003, 01:31 PM
CivicSiR7
CivicSiR7's Avatar
When I turn the key it doesn't turn over or even make a noise to try to crank the motor. The battery is still good, cause I got power. The only way to get it started is by push starting it.
Old 06-05-2003, 06:20 PM
purplx
purplx's Avatar
even though you replaced the starter, it sounds like a starter problem (no sound when turning the ignition, but you've got power), unless there is a wiring fault somewhere.
Old 06-05-2003, 06:53 PM
CivicSiR7
CivicSiR7's Avatar
OK guys thanks for the replys, I've found what the problem was. It was the clutch switch! Damn how was I STUPID! Not to check. Now its running. :thumbup: Thanks, again for giving me suggestions on whats wrong.
