ABS light is on.
Old 06-02-2003, 10:10 PM
ChoiceAccord
Pink Panty Bandit
ChoiceAccord's Avatar
Default ABS light is on.
I did a minor tune up on my 97 civic, the basic, cap rotor, plugs and wires. change the oil and filters. So I decided to change the brakes and the front rotors since the my girl friend warped the rotors. I was carefull not to mess with the abs sensor. now i have the abs light on inside the car. what could of caused that.
Old 06-03-2003, 02:29 AM
HouseofKolorEX
I get off on WD 40
HouseofKolorEX's Avatar
Just a stab in the dark, but did you check your fuse panel under the steering column to see if you blew the abs fuse? Sometimes fuses are the weirdest things.
Old 06-03-2003, 06:45 AM
Tirod
Tirod's Avatar
just pull the led off behind your gauges :chuckles: that'll fix 'er right up
Old 06-03-2003, 05:01 PM
ChoiceAccord
Pink Panty Bandit
I did that with my accord. but since i let my girlfriend drive's around in it with my little girl, I want it running right.
Old 06-04-2003, 04:29 PM
honda guy
honda guy's Avatar
did you try driving it yet sometimes maybe it came on if you had the key on while you were doing the brakes and by spinning the rotor the computer detected a wheel spin, just a guess but try driving it over 20 or 30 mph and see if it goes out.
Old 06-04-2003, 06:55 PM
hueman
hueman's Avatar
use human abs. no computer can keep up with the trained right foot of a road racer!
