what does your car idle at?
Old 07-03-2002, 01:19 PM
joebenz
nelson rules
joebenz's Avatar
Default what does your car idle at?
i got a 99 gsr. i'm not sure if somethin is wrong or not. but lately it's been idling at about 4-500. i thought before it used to idle higher. this started happening after i got my 30k mile maintenance done. so is this normal? or should i look at something.
no sig
Old 07-03-2002, 01:38 PM
b00gers
b00gers's Avatar
mines around 750-800 after warmup.
Old 07-03-2002, 01:45 PM
reech-around
RIP Woong.
reech-around's Avatar
keep in mind that the tach starts at 500.
anyway my idle is low, around 600. my ES motor mount inserts amplify the roughness, so my door panels and headliner rattle.
doh
Old 07-03-2002, 02:09 PM
reno96teg's Avatar
Old 07-03-2002, 03:14 PM
ur31337
Colby
ur31337's Avatar
Did they adjust your valves during that maintenance? When I had mine adjusted at 15K, my idle got low too. It went back up to 700-800 when warm after a week or so.
I don't imagine it would be a problem unless you hear it sputtering out or anything.
Old 07-03-2002, 04:53 PM
vtec2000
vtec2000's Avatar
My '00 GSR has always idled at around 400-500. I have 18k on the car. I haven't done a valve adjustment on it or anything....I plan on waiting 'till 30k.
Old 07-04-2002, 01:39 PM
Dariusz
Dariusz's Avatar
Manual says the normal idle is 600 to 800 (after warnup)
Old 07-05-2002, 03:11 PM
integramodder
integramodder's Avatar
no.
manual says: 750 +/- 50
unless you have the b18c5 in which case its 800 +/- 50
(rpms when car is warm)
Old 07-06-2002, 12:40 PM
DB7 2.0
Banned
DB7 2.0's Avatar
u sure its at 400-500? cuz like rich said...the stock tach starts off at 500. plus, the stock tach isnt exactly accurate..its about 200rpms off... i used to think my idle was really really low too and sometimes it even sounded like it was going to stall... i got it checked and it was at a rock solid 700 and when i put on my SAFC, it proved the "inaccuracy" of the stock tach.
Old 07-09-2002, 04:48 AM
Dariusz
Dariusz's Avatar
Originally posted by integramodder
no.
You are right, I read bad
Quick Reply: what does your car idle at?
