Washer trick
Old 05-15-2003, 09:02 PM
DIYguy
NWH's DIYguy
DIYguy's Avatar
Default Washer trick
ok, i did do a seach but none of the threads gave specific info really.
here's my situation. my rear alighment printout says
Left Rear
Camber: -1.7
Toe: 0.31
Right Rear
Camber: -1.6
Toe: 0.22
how many washer will i need? AND what KIND of washers. none of the threads never really told what kind or size...just how many
Old 05-15-2003, 10:47 PM
H-Accord-22
Duh
H-Accord-22's Avatar
5-6 washers/bolt, Type: flat, Size 10mm
Old 05-16-2003, 04:59 AM
DIYguy
NWH's DIYguy
DIYguy's Avatar
Why type material for bolt? how thick washers?
Old 05-16-2003, 09:52 PM
H-Accord-22
Duh
5-6 washers per bolt, washer's type: Flat, size 10mm or 3/8 (those with smaller diameter), about 1/16 thickness
Old 05-17-2003, 12:26 AM
DIYguy
NWH's DIYguy
DIYguy's Avatar
what thread size bolt?
Old 05-17-2003, 09:41 PM
H-Accord-22
Duh
Metric, 10mm Diameter, 1.25 Pitch, 60 mm long
Old 05-19-2003, 01:56 AM
TypeSH
TypeSH's Avatar
are you trying to get it to 0 degrees or -1.0?
I used i believe 4 and 6 1.75mm thick washers to correct for -0.8 and -1.2 to bring them both to around +1.2
I dont think the alignment sensors were perfect, but its a ballpark figure to estimate how many you need.
