Maintenance Required Light?
Old 05-12-2003, 06:19 PM
boblane
boblane's Avatar
Default Maintenance Required Light?
I can't find the manual for my 98 Honda Accord. How do you reset the mtc require light? Thanks.
Old 05-12-2003, 07:00 PM
jschmid
jschmid's Avatar
Something about turning the car off, then put it in "on" position, then hold down the trip odometer reset button until it quits blinking...that's what I remember from memory. Sorry if that's not entirely accurate, but try that.
Old 05-12-2003, 07:13 PM
Knight2dro
Knight2dro's Avatar
i think u hold the odometer button then put it in "on"
Old 05-13-2003, 08:56 AM
JimBlake
JimBlake's Avatar
Hold in the odometer reset button while you turn on the car, keep holding it in for maybe 10 or 15 seconds. I don't think you actually have to start the engine.
Old 05-13-2003, 09:00 AM
decibel_dj
decibel_dj's Avatar
did u get an oil change or anything along those lines?
if not its just the car telling u to get it looked at.. the same thing happens with the engine check light. once the problem is solved things will return to normal. howeva if u just want to lose the light every1 above my post already told u.. good luck
Old 05-13-2003, 09:44 AM
boblane
boblane's Avatar
As far as I know, that light just goes on every 7500 as a reminder. I'll try the tips for the light. Thanks.
Old 05-13-2003, 10:34 PM
adslinstaller
adslinstaller's Avatar
yeah, it goes on around 7500 miles. like they said - hold odometer reset button while turning key to on position & hold it in till light goes out. if it keeps coming on, you need to get the code scan done (which will turn the light out also).
mine came on & i thought it was cause i forgot to reset it once i had the oil changed, so i reset it. it came back on the next day & i went to the local parts store to have the code scanned (free of charge ) & it ended up being my cat going bad - found out 300 miles before warranty ran out otherwise it would've been $600 outta my pocket to have it replaced
so what i'm sayin is that "idiot" light as some people call 'em is there for a reason some times.
Old 05-16-2003, 07:34 AM
boblane
boblane's Avatar
Default Cat?
Cat? We talking catalytic convertor?
Old 05-16-2003, 07:44 AM
AcuraFanatic
AcuraFanatic's Avatar
Default Re: Cat?
:werd: Indeed.
Old 05-16-2003, 08:31 AM
boblane
boblane's Avatar
Default Thanks
I'll get the code scanned in that case. I can't get the light to turn off.
